Earth Question
Started by Johan_1955, September 22, 2020, 04:47:37 AM
Paul-R
The lines of flux are not solid like a fishing line or a railway line. They are positions of the effect that is a magnet.
Please explain how a neodymium outrunner motor works or if you accept the equivalence of an electromagnet and a magnetr, explain how ANY motor works.
Your reasoning is crap, your videos are crap, your knowledge of physics is about nil and if you claim to be a pilot and say that a compas doesn't work, then you are a fraud in this respect also.
I presume you believe the entire history of NASA is a fraud, from Alan Shepherd's suborbital to the moon landings and on to the ISS which is actually visible to everyone every so often.
Your standard of debate is insufficient. I can't be bothered with this anymore.
Paul-R
Quote from: lancaIV on October 25, 2020, 09:46:59 AM
#90 :
the worldwide.espacenet.com page entering
above ,left side "advanced search" field
f.e. Applicant : Vlaho Kucera
gives all what the searcher wants
'Original document' also readable
Sincerely
https://worldwide.espacenet.com/patent/search/family/025555143/publication/DE2644927A1?q=DE2644927
   "The homopolar magnet is horseshoe shaped, or specif. bar or rod shaped, and is formed from steel wire of any thickness and is placed on a flat bed or plate such that both ends of the horseshoe are directed towards the south terrestrial pole, or towards the north terrestrial pole, in the first instancE. As a result of the effect of the earth's magnetism the horseshoe shaped steel wire is magnetised such that both its poles acquire the same, polarity or sign. More specif. a rod of bar shaped steel is arranged with one of its end faces against the end face of an "artificial" magnet and in this way the rod becomes a homopolar magnet, and remains permanently magnetised, without regard to its position in space and time".
It won't work. Surely the whole thing wil become a (pathetically) weak "bar" magnet, aligned to the earth's field. Anyway, steel won't do.
Floor
Quote from Temporal Visitor.
"From the CIA you can find over 43 documents about a Flat Earth and a Firmament!?"
END of Quote
1. Not a single one of those articles,  is about a Flat Earth.
2. You can also write poetry upon a square of toilet paper.
If you wish, you can call that a "document" and strictly speaking, it would be.
3. It is a total stretch / B.S. stance, to refer to the materials discussed as     "CIA"
documents.
If it had instead, been pages from an old Time magazine, but downloaded from that declassified CIA trash dump site, would it have been an honest appraisal to refer to it as "CIA documents" ?. NO!
4. Its not a theory that the earth is a sphere.
                              Its a fact.
Suggestions..
Improve your communications skills.
1. Start with honesty.
2. Then clear unambiguous phraseology.
The first will require something which it is apparent you lack, (self honesty).
The second, will require that you acquire some ability to reason.
  good luck
       floor
onepower
Temporal visitor
You said there is no experiment to explain curved water which always seeks level. You are mistaken.
In fact there is and all water in outer space forms spheres and never flattens out. Look at all the pictures of free floating water in the space station or rockets which always form spheres in space. As well all the planets we can see are also spherical because most were molten or semi fluid at one point.
You do understand Earth is floating in space don't you?. Or is space a hoax as well, lol.
Johan_1955
This site is for: Free independent people!
Why some members are getting so fast louder?
