Free Energy RANT CAFFE ASYLUM
Started by v8karlo, October 02, 2020, 03:11:51 PM
sm0ky2
Quote from: AlienGrey on December 19, 2021, 01:22:02 PM
Watch this https://www.youtube.com/watch?v=tqFFdvheW1U
Awesome! I have a replica that TK made
I just made a label for it with your name
So i know what it is
onepower
smoky2
QuoteYup
https://youtu.be/rvDmJ_SfKao
Interesting video, did you know almost all successful inventors were good artists and had a tendency to sketch in 3D just as you have?. It goes towards the notion of them viewing the world around them as it is always acting within a volume in three dimensions. I do the same thing which really helps to understand things better.
The effect Wesley Gary found is very subtle and he claimed the working element could move less than 1mm and still produce the effect. So we could imagine the element moving within a small region where the field transitions from one polarity to the other... a neutral zone of sorts.
Logically it makes sense, most people utilize the magnetic poles which are always unipolar while other regions have neither polarity. It goes towards the notion expressed by Walter Russell that one state/polarity cannot transition into another state/polarity without becoming neither state or zero in the process. Logically the law is irrefutable, if some thing transitioned from one state to another then in the transition it must have became neither state or zero otherwise it couldn't make the transition.
Thus there must be zero points within the field which Wesley Gary referred to. You won't find this in a textbook and some experimentation is required. I used an magnetometer to map the fields and a simple magnetic polarity probe doesn't have the required resolution to find the transition. A piece of wire 1" long attached to the end of a wooden stick forming a "T" works well.
We should also understand the difficulty involved. It took Wesley Gary years to find this effect then more years to understand it well enough to capitalize on the effect. However modern tools like magnetic field and force sensors make the process much easier.
AC
sm0ky2
I did not know that. It was actually difficult for me to draw
a 3-d object sitting on a 2-d plane, drawn on a 2-d plane....
Felt like i was doing some MC Escher thing....
Took a few tries to make it look correct.
There are 3 neutral planes, perpendicular to the magnetic origin.
One in each of the 3 dimensions, as i try to show in the video.
It follows reason that a field occupying a larger physical space,
would have a larger neutral zone.
However, experimenters report success neutralizing rods of about
1/8 - 1/16 inch thickness,
Through a range of about the same (pole to pole through the null)
Any method can be used to vibrate the rod up and down
The whole of the Wesley Device was a mechanical crankbox designed to
do just that.
19-inch horseshoe on the way from Amazon
Kind of excited to play with this. I can't believe i have never seen this before
From the 1870's!!!!
The way he describes the effect explains quite a few anomalies that have popped up
over the years.
I have verified the theory by physical experiments
everything except the power generation part.
But thats as simple as winding a coil and making it oscillate
sm0ky2
It would be nice to have electronic gauss meters etc....
But this can be done using a compass or magnetized needle on a string
Or even with a few iron filings
seychelles
