Free Energy RANT CAFFE ASYLUM
Started by v8karlo, October 02, 2020, 03:11:51 PM
AlienGrey
The above device inst actually new and the coil in the Jean labs photo looks fairly bulky.
See the device he says he made
ramset
AG
The other day you posted something about vibrating ( resonance?) a split core
To resonate or sweep or ?
Both??
Is this https://www.overunityresearch.com/index.php?topic=3683.0
Post 14 Vasik ?
BTW
Thanks for input on Experiment posted above ( synergetics)
Going to see if original person ( builder) that showed 400 percent gain is still
Around !( Dutchman ?)
Thanks Grandma
AlienGrey
No don't know that Vasik41 posting.
It's a well known phenomenon if you get an iron bar and and tap it will vibrate 'ring' if it doesn't then this experiment wont work if it does then the trick is to put a coil on each leg and wire the coils in series and put another bar of iron
at the bottom linking the two legs (it wont stick') but if you pulse the coils it will stick.
Now if you put some ceramic head phones across the coil you will hear a rushing sound, but if you                                                         separate the bar from the legs it will all stop.
Now if you pulse the coils with AC you will be altering the distance between the legs and modulating the magnetic
influence between them.
Russ Grease did a video about this phenomenon. its called resonance.
ramset
Well
A bit more help on that post you referred too ?
Lots of empty links ?
Also
Just for FE gossip at the open source garden fence !
https://www.overunityresearch.com/index.php?topic=4389.msg102207;topicseen#msg102207
Anyhoo..
Lots of things cooking in the open source FE world !
Hopefully like nothing we have ever seen before !
Let's get this done ....
Half measures afford us nothing!
Respectfully
Chet K
Thanks Grandma
AlienGrey
