AC voltage from single magnetic pole
Started by nix85, October 04, 2020, 10:16:36 PM
nix85
Ramset, here is something more than an anomaly, altho low speed and torque, real working magnet only motor. You can see how he placed magnets at 90° to cancel resistance and how extremely delicate it is. Just one simple, raw example.
https://youtu.be/vkcFRLQiVGk?list=PLS6CmWwu5VGmYsgX5-2kFtPsE-iIsXj_o&t=161
nix85
partzman here is one valid replication of Kapanadze from Russia, unless you think it's fake.
https://www.youtube.com/watch?v=YNMkiIov5NM
nix85
Few flywheel vids too
https://www.youtube.com/playlist?list=PLS6CmWwu5VGl_vd5AX8FRPp7_nSc3vWbo
Here is a 'secret' for you if you will replicate the flywheel system, use 2:1 reduction from motor to flywheel and 2:1 from flywheel to low rpm alternator (or even 3:1 and 3:1). Flywheel should be 60kg and 60cm wide for 3-4kw excess power. Have not tried this, these are instructions from guy from Brazil who left a comment on YT video with failed flywheel experiment and gave instructions how he succeeded.
nix85
Forgot to answer about Rick Friedrich, i am subbed to his channel but that is more less only for entertainment value.
verpies
Quote from: nix85 on October 08, 2020, 08:23:17 AM
I am not avoiding anything
Let's see if that's really true...
You didn't even know the direction of induced voltage nor the current lagging voltage in an inductor,
So below is ANOTHER question for you:
Q: Why do you think that "the current lagging voltage in an inductor" is relevant to the case of a permanent magnet moving across a simple air core coil, as in this video, which was the subject of our discussion ?
How will you avoid answering it this time?  Will you:
1) call me a derogatory name,
2) use an excuse that it is "unclear",
3) use an excuse that it is "irrelevant",
4) use an excuse that it is "too complicated",
5) use an excuse that it is "too simple",
6) claim that if I have to ask that, then you have no comment,
7) claim it is nonsense,
8 ) write "Bla Bla",
9) write that "the sky is blue",
10) ...just ignore it ?
