Капанадзе
Started by justawatt, October 20, 2020, 03:25:53 PM
r2fpl
Your FE is resonance with time. This information is the key, and when it is misunderstood, it is nothing.
Do you really think someone will show a real device here with step by step instructions?
Void: You're right, but there are conditions under which such a process is possible. So I wrote a repeat earlier: joining the currents!
v8karlo
50 Hz on aircore?
Maybe it can be? Everything is possible!
I am open to all kind of stuff, still.
Void
Quote from: Jeg on October 28, 2020, 12:35:48 PM
Void
Look at the thick copper pipe which drives his Tesla coils. If it not the resonant Fo it is for sure a harmonic of it.
Hi Jeg. I have made it clear I am talking about the 'all in one' circuit.
There is only the long air core coil on what looks a carboard tube,
and the thicker wire output 'bucking coil'. I don't know why you would spend time
on the 'monster' circuit when the 'all in one' circuit is simpler and
is still supposed to supply at least 2kW at the output.
Quote from: justawatt on October 28, 2020, 01:20:47 PM
jeg
Well said this is not a tesla coil,the driver is working in 50hz range,so harmonics is the key,
this device is not about resonance
Hi justawatt.
I have been talking about the 'all in one' circuit. It is a simpler setup to analyze.
I stated it appears to me the coil (or possibly coils) on the long coil
do not appear to me to be operated at natural resonance, and I explained why I think that.
You say harmonics is the key, as if you know that for sure.
What makes you think that is the case? If the 'all in one' circuit is dependent on
operating at natural coil resonance, or some resonant wavelength fraction, it would be susceptible
to getting untuned when you placed your arm or hand near it, or when you changed the
load connected to the output coil. If you have a larger value capacitor connected
across part or all of the long coil, forming a tank circuit, that would probably show
more stability, but they don't appear to have any such capacitor connected to the long coil.
Anyway, I'll let you guys have at it.
If the 'all in one' circuit is legit, it should be based on a fairly simple concept,
as there is just not too much to that particular setup that I can see.
Quote from: r2fpl on October 28, 2020, 02:34:49 PM
Hi r2fpl. I have an open mind. :)
r2fpl
Quote from: Jeg on October 28, 2020, 02:23:37 PM
Hi JustaWatt
In the contrary i believe it is a matter of resonance. But not at the fundamendal frequency.
I don't doubt that it is a driver for 50Hz. But internally he has an oscillator for high frequencies. MHz range. There is no way for inducing lower frequencies in the range of hz through a loose coupled thick copper pipe. This is Tesla driving clearly. And very probably modulated at 50Hz.
Yes, ballast works in a modulated phase 50 / 60Hz system, for example with a frequency of 47Khz which for TT can excite on Mhz. If only one power stage is working, it will be pulses! not sine when the ballast works with the lamp.
Void: I can see the pickup method on Bunk. These are the two Tesla coils that act like a tuning fork.   (if this is a trick we are making fools of ourselves)
Void
Quote from: r2fpl on October 28, 2020, 02:41:48 PM
Hi r2fpl. The chances of any such device really being OU is not very good,
especially in this case, as the 'all in one' setup seems to have very little to it.
However, I always try to keep an open mind as you just never know what might be possible
as long as you have the right concept. Kapanadze said his setup is based on a very simple concept,
if he was telling the truth. :)
