Капанадзе
Started by justawatt, October 20, 2020, 03:25:53 PM
niyazzi
Unfortunately, I do not know how your wires are marked.I'll try to explain. An all-in-one coil uses two wires. Wire diameter without lacquer insulation of the light coil( it is larger) it is 0.31 mm. Diameter of the dark coil wire( it is shorter) 0.5 mm .Both coils are wound in the same direction. This was found out from the author of the installation. The same coil imho is a Tesla-kacher in the installation - "Monster" Look carefully at the photos of both installations.
niyazzi
This is a unit for lighting fluorescent lamps in 1995. But all of it is not used. Just a part of it.
niyazzi
Justawatt. I looked in swg. Yes 30swg and 25swg
This is not the most important thing. Bunk said that when a wire of the same diameter was wound, it was possible to get a power of only 200W. When wound with different wires, the power increased to 2500W. A small deviation from the diameters is not critical. I think the length of each wire is more important.The photo is very difficult to determine. Bunk hasn't said anything about the length of the wires yet, either.
Void
Hello Niyazzi. If you have some free time sometime, can you translate the Russian words
on the attached schematic into English? Or provide the Russian words from the schematic in Russian
text format here, and I will translate into English.
Если у вас есть свободное время, можете ли вы перевести русские слова?
на прилагаемой схеме на английском языке? Или предоставьте русские слова из схемы на русском языке
текстовый формат здесь, и я переведу на английский.
All the best...
niyazzi
