Капанадзе
Started by justawatt, October 20, 2020, 03:25:53 PM
Void
Quote from: justawatt on October 24, 2020, 07:02:47 AM
See this what happens  people trying to  find hidden  wires.
Rather than try to figure out  its working.
Hello justawatt. I try to keep an open mind, as you just never know for sure about these circuits.
However, realistically, the chances of one of these devices being legitimate is very small.
The reason I had more confidence in demonstrations from Kapanadze and Akula is because
they allowed independent third parties to view their demonstrations up close in person.
That adds more weight to their claims. Here, I think, so far this is not the case with Bunk?
I just had time to watch an early video from Bunk called "Капанадзе 14.09.2020.mp4".
I saw something in this video which raises some very potential alarm bells:
At 04:29 in this video, you can see that the 9V battery was clearly disconnected.
At 04:32 in this video, only then does the light bulb turn off.
That is about 3 seconds after the 9V battery was disconnected.
That is not a guarantee of the video demonstration being a trick, but it is very suspicious.
Anyway, I am keeping an open mind, but based on what I saw in "Капанадзе 14.09.2020.mp4",
it does look quite suspicious. I will let you guys continue to analyze the device. Maybe there is some
important concept which we are missing. I don't want to discourage anyone, but I thought I should
mention what looks very suspicious to me in that earlier Bunk video demonstration which I described here.
All the best.
niyazzi
Now look at the photo. L4 is added with a black wire. Bunk said he was missing a yellow-green wire. It follows that L4 is not taken arbitrarily. I do not know how to adjust it - by length or by inductance. When I tried to calculate the length of the wires from the photo, I got - L2. 1=L4+L1+the length of the connecting wires.The ends of L1 are wrapped with electrical tape. It is also possible to adjust by sliding the wires in L1.
Void
Quote from: niyazzi on October 25, 2020, 01:20:49 AM
I also had my doubts. Because the kacher frequency changes even as the hand approaches. And in the video, they move the installation, bring their hands closer ,connect the load. Nothing changes. Googlodrom said that it is not kacher. The output is 260 volts, 193 Hz
Thanks Niyazzi.
niyazzi
Void.Bunk talks about this in the video. The installation does not turn on immediately, but after some time. It doesn't turn off immediately either. Apparently, charging the capacitor is enough for some time.
Void
Quote from: niyazzi on October 26, 2020, 12:21:33 AM
Hello Niyazzi. Don't forget that the early 'all in one' circuit only had one tube.
It doesn't appear to have L4. It seems to be a more simple arrangement. It should
therefore maybe be easier to analyze that circuit arrangement.
Edit: If the 'all in one' circuit can produce a large COP (energy gain), i.e., if it can
power a light bulb and an electric water kettle from a 9V battery as shown in the video
"Капанадзе 14.09.2020.mp4",  then it should be easier to try to replicate that simpler circuit.
No need to worry about the more complicated circuit arrangement.
All the best.
