A Working Radiant Free Energy System
Started by callanan, January 05, 2007, 01:46:30 AM
hartiberlin
Hi Ossi,
can you or somebody else please post your DOC file
as PDF or just the Ascii text inside a reply posting ?
Not everybody has Winword installed.
Many thanks.
Regards, Stefan.
P.S. Motor looks nice !
gezgin
Hi,
i have one 12 V battery, a reed switch, 3055 etc.
can i use  this device single battery charge with some modification,
I have seen miracles happen to men and women in all walks of life all over the world. Miracles will happen to you, too?when you begin using the magic power of your subconscious mind -Joseph Murphy
gyulasun
Quote from: hartiberlin on January 11, 2007, 12:58:44 AM
Hi Ossi,
Many thanks.
Regards, Stefan.
Hi Stefan and All,
The Windows XP (as all earlier Windows versions) has the Wordpad built-in text editor which is able to open documentum files too.  (At least I can open Ossie's file with the Wordpad too.)  The other built-in text editor, the Notepad is NOT able to open it, it is for text files only.
The Wordpad can be found by clicking START -->All Programs --> Accessories.
rgds
Gyula
AhuraMazda
Hi Ossi,
Many thanks.
Regards, Stefan.
Steffan,
PDF version.
AM
callanan
Hi all, some responses:
> Is it possible that you are using the potential from the reac?
Absolutely. Is there more than one way to use and connect the REAC? Absolutely.
> I like your presentation and it obviously represents a lot of work on your part.
Actually, it represents only very little of the work I have done over the years in this field.
> the problem is , that the fully current from the inductor coil will flow over the read-contact !! Why?
Correct, but only for a very small fraction of time. Overall power through the reed, when you take into account time, is very little.
> Can you tell me what the purpose of the neon is?
To save you money replacing the transistor when you forget to connect the output battery then connect the input battery.
> What is the purpose of your paper and this thread?
To show others, who are interested in building things in this field, a simply radiant energy device and system they can build with common components and get some real OU results.
Regards,
Ossie Callanan
