A Working Radiant Free Energy System
Started by callanan, January 05, 2007, 01:46:30 AM
hartiberlin
Thanks for the PDF,
I am in this moment at a Win98 PC, where the
Windows Wordviewer is not working and
I did not want to install OpenOffice.
Ossie,
it seems you are exactly doing, what Newman did
with several mechanical switches in series.
You need the mechanical switching for the effect to take
place.
The neon bulb parallel to the transistor also helps to get
the spark converted to glow discharge region, where
we have partial negative resistance.
If you put in series with the coil an incandescent bulb,
you probably can light it by these Current spikes and RF bursts.
If you go to:
http://tech.groups.yahoo.com/group/newmantech/files/new%20Newman%20ASF%20movies/
and watch the 5th, 6th 7th and 8th video
there, you can see, how bright the incandescent bulb in series
with Newman?s motor coil lights up, due to the RF bursts of his
mechanical commutator.
Also these RF bursts can destroy the sulfate of old batteries and
can make them come to live again, so I guess Ossie your REAC is
a good idea to use.
After a while these batteries might be indeed again pretty good
in health.
Regards, Stefan.
gezgin
Hi Ossi Callanan, thanks for your open source device and text.
im trying circuit with 12V charged battery, 6V dead battery, reed switch,
coil (2x12V transformer coil), small neon,2n3055 but ,
reed swtich normally open and  transistor doesnt work first time.
when small speaker magnet approching, neon lamp short time blinks.
how can i solve this problem, continiuos ossillation how can be do?
your reed switch diffirent? or my transformer coil isnt enought? is your coil wire 0.5mm?
Stefan,
I look yahoo grup files but they are very small size with media player asf files.
in there,  i see your  charger circuit with 8W fluoresant tube, self running vibrator relay switch.can i use normal relay or another component instead of vibrator switch?
thanks,
I have seen miracles happen to men and women in all walks of life all over the world. Miracles will happen to you, too?when you begin using the magic power of your subconscious mind -Joseph Murphy
arbus
hi ppls,
Maybe instead of the reed switch a trigger coil can be used. with a relay?
This should allow the switching at the same time as the reed sw. but with better contacts.
just wrap the trigger coil around the end of the existing coils core, and test the number of windings to get the correct trigger voltage.
Ar
AhuraMazda
I really think anyone who is interested in what Ossie has published should first try to replicate Ossie's work. After that, you can modify anything you want. Read what has said so far carefully and take note before building.
AM
gezgin
