A Working Radiant Free Energy System
Started by callanan, January 05, 2007, 01:46:30 AM
pese
So Callanan.
The scematic is with some problems
Not only to take an faster switching diode.
the problem is , that the fully current from
the inductor coil will flow over the read-contact !!
Why?
The 2N3055 Transistor is NOTHING WORKING to amplifying CURRENTS
IF the Base is conected to Collector !!
So the fully current flow only VIA the BASE-EMITTER Diode .
Also if some more "inventors" use this circuit , it will not be better
from them.
Possibly this circuit work , but the REED-Contact will "fire and burn".
Find another way to eleminate that "bug".
Pese
callanan
Hi all,
Let's just look at my reed motor without any REAC connected. Just a battery on the input and a battery on the output. Let's have a look at it's performance as a motor and a motor generator. Firstly I would like to show you how to make the reed switching reliable. See the attached pictures:
Use large/larger reed switches. These reeds have a glass that is 27mm long by 4mm thick. Using exactly the same circuit, put two reed switches in series instead of one. Except mount them such that they are oriented 90 degrees from each other as in the attached pictures. The horizontal reed will oscillate with the coils magnetic field as previously described, but the vertical reed will simply switch on and off. The problem with one reed mounted horizontally is that it sticks and as a consequence the coil stays on and it's magnetic field further holds the reed closed. With this dual reed setup, the vertical reed prevents the coil staying on if the horizontal reed sticks and as the magnetic field is removed when the vertical reed opens so the horizontal reed opens again and both reeds are reset.
The motor is driven by four coils all switched by dual reeds using the same circuit. The motor is in the following picture.
Now here are some interesting facts about the motor's performance that I think you will find interesting. This motor for some reason always spins at a hefty 1200 RPM, almost exactly, no matter what input voltage you apply to it. If you raise the input voltage, the input current drawn goes down.
It spins very, very fast for the little energy it appears to be using. To get this rotor to spins at 1200 RPM using other types of coil drive circuits the motor would typically use at least a few watts. Now just take a look at the following measurements made with an analogue ammeter and a digital volt meter.
With an input of 50 volts, the motor draws only 100ma. So that is an input power of exactly 5 watts. Now here's the clincher! Charging a battery that reads 10.8 volts whilst connected and charging from this motor, the motor is sending 400ma into the this battery! That is an output of 4.32 watts!!! So that means that this motor is only using 680 milliwatts but still manages to run at 1200 RPM!!! This is a fairly heavy rotor with large bearing and considerable magnetic drag. That is an amazing amount of torque for just 680 milliwatts don't you think?
Regards,
Ossie Callanan
arbus
Hi Ossie,
Can you tell me what the purpose of the neon is?
Have you done experiments with the reac? using a capacitor? or a bank of capacitors?  Maybe you are zapping the reac batteries and forming some sort of chemical reaction? I am not sure if radiant energy can be stored in a capacitor, i think it can, but it dosent convert it to electricity?
Can you tell me what your power source is? Have you increased it from 12V to 50V? Not that its that important, i am just trying to follow and understand how it is working..
I would like to see what happens if you set up the switching on a different circuit, so that the motor operating battery is not the same as the charging battery.  In theory it should be able to charge the battery with very little drain.
AR
gaby de wilde
Quote from: callanan on January 05, 2007, 01:46:30 AM
Please see the attached document. Any comments. questions welcomed. But only nice ones responded to.
Regards,
Ossie Callanan
most impressive!
My suggestion is to make the coils huge so that the reed doesn't switch as often.
Big machines are also more impressive.  :D
blog  | papers | tech | inventors  | video
AhuraMazda
Callanon,
1- If a battery is charged conventionally, can it also be charged with RE? I mean can the battery hold both types of charge sinmoultaneously.
2- How long do the read relays last?
3- Have you tried semiconductors instead of the read relay?
AM
