500 kw device from USA
Started by justawatt, October 29, 2020, 01:19:16 AM
Void
"It is powered by a Micro-Sonic Energy Device (MSED). The MSED is a technology that generates electrical power by converting high radio frequency energy directly into electricity. "
Unfortunately, that sounds like pure gibberish.
They use the term "micro-sonic", 'sonic' meaning relating to sound or sound waves.
Then they say it generates electrical power "by converting high radio frequency energy directly into electricity",
which, for one thing, has nothing to do with sound or sound waves!
Second, what "high radio frequency energy" do they convert?  Notice they specifically say "radio frequency",
so they are not talking about gamma radiation or something like that.
Any energy you can collect from radiated radio frequency EM waves is only relatively quite small. You'd be lucky
if you can very very slowly charge up a cell phone battery from that type of EM 'smog'.
They might as well say it gathers high energy using a flux capacitor held at absolute zero and spinning counter-clockwise at warp speed.  ;D
stivep
inventor
Maxwell Chikumbutso
South  Africa:
-he dropped school at  age  of 14th.
https://youtu.be/viGjXV38qvY?t=34
quote:
QuoteMaxwell Chikumbutso developed his technology through  research and vision from God
_______________________________________
spiritual   organizations  support is here:
https://www.youtube.com/watch?v=R0CvyfIuoGU
some other material:
https://youtu.be/kFFqfP9frIU?t=59
https://www.youtube.com/watch?v=WOMJpiB-TFo
all other videos:
https://www.youtube.com/channel/UCvrTw0z9drF3JJ0nun6W52w/videos
videos  are  pure  Bs......... like bulls*t
Is  such technology worth something?
if there is any technology  than according to  inverse square law   at spectrum of frequencies between 100kHz to infinity?
has the available joined energy that depends from distance of near by transmitters.
In far field it could be  few  W at maximum if  intercepted and rectified.
In near field  it is good amount of power
But for 100khz  the   Near field calculation is
here:
https://www.everythingrf.com/rf-calculators/antenna-near-field-distance-calculator
There are  three examples:
-1m       length of wire in the coil
-100m   length of wire in the coil
-1000m length of wire in the coil
_______________
- the frequency  of  Rx is 100kHz
- the NEAR FIELD  from the antenna of Transmitter is  shown in Green color ( look at the middle upper part of the   picture)
another words it is inductive reactance that matters ..
I'm quite.. quite surprised  I must check it out..
Wesley
stivep
Fallowing statement applies  to energy  of FAR FIELD :
If we assume that  we  can theoretically  combine  all of the man made  energy  of
entire spectrum from 100kHz up  to infinity
especially in  region of South of Africa
based on inverse  square law we would be able to run
not more than   a mid size drone..
Wesley
stivep
Rule of energy interception with  minimum losses:
Rule #1 -Rx- (receiver) must  have resonance circuit and impedance match at entire  spectrum..( impossible to be done)
              Rx- receiver antenna is more forgiving than Tx antenna in regards to impedance/resonance  mismatch
Rule #2 -Photon is the carrier of RF energy
Rule #3 -Photon at every and  any  frequency  don't see  any other photons or any  photons at all,  and can't interact with them.
Rule #4 -Photon also can not see other  photons from the same  Tx
Rule#5 - Photon can only interact with itself.
Rule#6 - Photon interacts with mass and deposits its energy in form  of heat.
Rule#7 - Photon interacting with resonating mass deposits its energy in that mass( coil/ resonance circuit)and we prevent this energy from being  wasted  in a heat.
             we take this energy , we add energy to it and  we amplify it to the level    comfortable to us.
conclusion:
We lose energy  when we transmit it,  and we lose energy to amplify signal when we receive  it.
Wesley
stivep
There are idiots out there .....
facing me
-the idiot in the fields other  than my field of an expertise..
And that makes you valuable idiots  coming to me into my  field and asking questions.
______________
At some point  I can become lesbi-anal-itical  and even les-of an-idiot in that what you know and I don't.
But till than you need  me  for sure..
Wesley
