Chinese Oscillator and MOS FET Driver, Hardware experiment
Started by AlienGrey, November 13, 2020, 04:37:08 PM
magpwr
Quote from: ramset on November 14, 2020, 08:37:12 AM
https://m.youtube.com/watch?feature=youtu.be&v=jtKnXeJ0VEg
AG
This is the Device in thread tittle above !
Or is that something else ?
Hi,
I have assume you guys already know that youtube can do translation of Russian,Chinese and etc video with English subtitles provided you duplicate the video and give youtube money for a good technical translation.
My Mandarin  studied in school outside of China never taught technical,components,computer parts definition in Chinese.It is just one of the 4 languages i acquired.  :D
synchro1
The Dielectric field is powering the loads. JEG's illuminated bulb should stay lit submerged in water!
Tesla's Hairpin circuit plays the same trick capacitively. Master Ivo's setup amounts to basically the same thing.
The power is not traveling through the wires as current but through the capacitive shell as voltage!
synchro1
The challenge for JEG is to try and run his Black and Decker jig saw underwater!
Jeg
Quote from: synchro1 on December 05, 2020, 10:26:08 AM
The addition of a high voltage trimmer capacitor in parralell with the 8000V capacitor would allow for finer tuning to higher "Q" and consequently higher voltage. Results are already awesome!
I bet the Chinese inventor burned a trimmer cap out fishing for high "Q" then replaced it with the two additional 0.47uf resonators. You may need to start over to find the correct combination.
Merely a few centimeters difference in coil wire length can offset the LC "Q" enough to reqire an adjustment in the picofarad range. Fine tuning can double the tank voltage!
This is like getting real power from VARS. Phase angle Voodoo? I wonder if power would rise to meet the load if you put the reciprocal saw to work?
Hi Synchro
The Chineese eng. use two caps of 0,047uF (not 0,47uF as i wrote above) in parallel with his ZVS primaries, total input capacity of 94nF/2000V. The in series cap is of 22nF/8000v capacity. In my case, by using a 100nF at the input, it rings at 110KHz. I needed a 10nF-12nF capacitor at the resonant circuit to tune. I was thinking to match the impedances between the separate circuits by using Don Smith's nomograph. (I attach it below). But the Chineese seems that he didn't bother with that. Nevertheless he feeds successively a 2KW load running it at 198-200Volts!!! So according to what i see on my bench, he might has a secret ingredient which is hidden!!??
The fine tuning is off of the table for me. Each load you add, changes the resonant point of the tank circuit! If i was to match the impedances by using the nomograph, i would have to go down to 30-35KHz to meet a 30-50 ohm impedance which suggests a load of about 1.5KW. But clearly this is not the point. The capacitors he uses suggest an impedance of about 100-150 ohm. Something doesn't fit here. So everything point out that the Chineese uses a separate technique to raise his voltage across the tank circuit. Time will show. :)
MasterPlaster
I think the frequency can be easily varied by the 2000v0.094uF.
