Chinese Oscillator and MOS FET Driver, Hardware experiment
Started by AlienGrey, November 13, 2020, 04:37:08 PM
color
China-Kapagen-Winding ferrite transformer
https://www.youtube.com/watch?v=lUh8hHWrGvI
The power generation technology above is also similar to the'Captor' energy.
The universality of generators using'captor' technology is low voltage high current.
French people use this technique these days. ;D
Jeg
If there was only one turn then why we see wires over the center tap?
conico
Maybe he make 2 turns not just one, 5 turns make a low voltaje and to low amperaje.
Yes , the 5 wires are long but he can make maxim 2 turns not 5.
An other explanation . you can see the ferrite road is very well isolated with paper or plastic , the wires do't reach the ferrite part because the voltage is high.
the question is where the secondary with 28 turns is wound?
color
Jeg :
If the wires in the center tap are separated from each other, the amount of current cannot be collected, but since they are connected, the only function is to convert the ferrite's magnetism into electronic energy.
Since ancient times, the role of ferrite is all about energy conversion.
https://www.youtube.com/channel/UCEtqI2EhN32Mvq7Wp5G9Vpg/videos
https://www.youtube.com/watch?v=mHuzHKf-ahM
No matter how you change the size of the ferrite or the shape of the wire, people confuse it with another generator because they have the same role to convert energy, but the principle is the same. ;D
