Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
bob.rennips
Take a look at this patent:
Patent number: 413353
http://patft.uspto.gov/netahtml/PTO/srchnum.htm
OR as gyulasun point out if you dont have the TIFF plug in use this link
http://www.pat2pdf.org/patents/pat413353.pdf
(thanks to gyulasun for the above link)
Inparticular take a look at FIGURE 2.
What is interesting is that what is described is a method of converting AC into DC without the use of diodes but using transformers. i.e. of rectifying the AC into rippled DC WITHOUT diodes. Why is this important ? Because this method can recitify as high a voltage as the coils can withstand. In other words where traditional diodes allow momentary reverese currents as the breakdown voltage of the diode is momentarily exceeded (due to small kicks combining into large kicks) this method would not suffer this. The correct combination of coils could allow the kicks to be continually combined to ever larger voltages whilst also allowing for part of the circuit to be DC and hence one of the coils to have Dc current.
Now obviously in the TPU we have coils wrapped on coils, connected in parallel and in serial, there is transformer action, even though this is not the direct way of working of the device.
Consider, if the correct operation of the TPU requires exceeding high peak voltages to be used AND it requires that certain coils are predominantly high voltage DC in nature, how would this effect how we perform our experiments ?
What use is a DC coil/solenoid ? Within a DC coil you have a uniform magnetic field in ONE direction. A charged particle that enters this uniform magnetic field at right angles will follow a CIRCULAR PATH.
So imagine this as a possibility:
1. High voltage abrupt 'KICKS' cause radiant energy to be release.
2. Tesla had said himself that this 'energy' felt like being hit by high speed particles, a stinging effect.
3. These particles cause a charging effect on nearby metal. Both Tesla observed this and Steven Marks has warned DONT touch any metal on the device once you think you may have some anomalous event.
4. If these charged particles enter a high intensity uniform magnetic field they will go round in a CIRCLE.
5. Circular rotating charges will by defintion cause a rotating magnetic field.
6. A rotating magnetic field would also be ADDITIVE to the already rotating magnetic field that produces the KICKS. Creating even bigger kicks. Here is a feedback effect that could easily get out of control.
The DC coil is crucial to this theory working.
You could have 1000V DC with 200V AC ripple on it and you would still get the circular rotation of particles. But if you have 150V DC with 200V AC ripple you would not get the rotation of particles.
So you could have everything else perfect but without the DC being right, the device will not operate.
For our experimental and investigation purposes we can however get around this problem. If we separately apply a high (1000V) DC voltage from a high voltage bench power source, to the largest diameter coils, we can mitigate this problem. We can then observe what happens and see if this theory has any merit.
Any comments on this theory ? If moderators think this should be in a separate thread please shout out or transfer this posting to a separate thread.
bob.rennips
Quote from: Mannix on April 15, 2007, 08:40:35 AM
Either you have performed Otto's little test of 7 months ago or you haven't.
Its is that simple really.
Lindsay
For those of us that missed that crucial post, 7 months ago, could you explain Otto's simple test or point to the original posting ? Many thanks.
bob.rennips
Further to the posting on possible DC coil aspect of the TPU.
Also consider the exploding TV described by Steven Marks.
Could the ciruitry fail in a TV so that the deflection yoke that steers the electron beams or the demagnetisation coil, fail to a state of a continuous DC current applied to one of these coils ? I would say it's possible but not likely. (DC coil effect)
Could the flyback transformer (or other high voltage device) fail in such a way that very high voltage sparks are generated ? I would say that's possible but not likely. (Kicks, Radiant particle effect)
Could the above also concur with the production of a rotating magnetic field ? I would say it's possible but not likely. (Rotating magnetic field).
The combination of events is highly unlikely but again this IS what is observed. Only a very, very small proportion of TV sets have exploded in a bizarre fashion.
giantkiller
Quote from: bob.rennips on April 15, 2007, 10:04:04 AM
Think about this:
What if the flyback was built using standard transformers. The strange coupling that occurs would be a large field in the field of the yoke and the tube. Basically an open Tesla coil. I mention this because the exploding tv exhibits the same matter in motion that Hutchison's experiments exhibit.
Could the tvs have been recalled very quickly under the guise as a threat to the consumer?
This one has been bothering me ever since I read it. Those of us that have produced kicks and have pets have noticed the animals flee the area. Go figure, eh?
--giantkiller.
gyulasun
Hi All,
For those wishing to see Tesla patent 413353 but do not have TIFF picture viewer installed that is needed at the US Patent Office link,  here is another link to see the patent in PDF file format:
Gyula
