Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
d3adp00l
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
giantkiller
For all you cowboys and renegades out there:
This TPU project is a mind blowing, mind growing deal!
Fermilab is the mainframe, the tpu is the micro. The effects on the desktop are the same.
http://rexresearch.com/barbat/barbat.htm
Read the reference list. Pm'd by a TPU buddy. THX1138.
--giantkiller. Shut up and keep up!
Rosphere
A FIRST COURSE IN PHYSICS
Millikan and Gale
1906, 1913
Revised Edition
Page 272
giantkiller
Quote from: giantkiller on April 25, 2007, 11:59:16 PM
The patent is full of information pertaining to all the mysterious OU devices and accompaning physics. But all I can see is the guy is trying to patent why water flows downhill. I didn't see any new devices or at least nothing we haven't been working with. This is basically a Name it and claim it sheet. He has nothing and I don't see how it received any patent status at all.
--giantkiller. This toilet paper won't stop me!
tak22
@gk
I disagree with your Barbat assesment. Quality clues are hard to come by!
http://www.overunity.com/index.php/topic,2255.0.html
Here's a text block from the Mode of Operation section that speaks for itself:
[0092] The oscillations in the energy-magnifying coil are initiated by an external energy-input source that provides an initiating impulse of electron flow in the sending coil. For example, the external energy-input source can be an adjacent independent electromagnet or an adjacent permanent magnet moved rapidly relative to the sending coil. The initiating impulse commences an oscillation in the sending coil that stimulates radiation of inductive photons from the sending coil to the energy-magnifying coil. Energy from the external energy-input source is magnified by the apparatus so long as the energy-magnifying coil does not act as an independent oscillator at a different frequency. Independent oscillation is desirably avoided by connecting the ends or terminals of the energy-magnifying coil to each other in such a way that it results in one continuous coil, or a continuous multiple-coil system or systems, connected together in such a way that continuity exists for the conduction of low-mass electrons throughout the entire coil system. The energy-magnifying coil inductively creates more energy in the output coil than the energy of the initial impulse. The resulting magnified output of electrical energy produced by the apparatus is available for useful purposes in a work loop.
[0093] After initiation the apparatus is made self-sustaining using a feed-back loop arranged in parallel with the work loop that includes the sending coil, and with a capacitor located in the feed-back loop to make it an L-C circuit. I.e., after start-up of the apparatus using the external energy-input source, the apparatus becomes self-resonating, which allows the external energy-input source to be decoupled from the apparatus without causing the apparatus to cease production of electrical energy.
[0094] During normal self-sustained operation, a portion of the output electrical energy is returned to the sending coil by the feed-back loop, thereby obviating the need to use the external energy-input source for sustaining the oscillations in the sending coil. In other words, after startup the external energy that was used by the sending coil to excite the photoconductive material or the superconducting material in the energy-magnifying coil is replaced by a portion of the output energy produced by the apparatus itself. The remainder of the output electrical energy is available in the work loop for useful purposes.
[0095] Initiating the generation of electrical energy by the apparatus takes advantage of the fact that the inductive back-force sent from the output coil to the energy-magnifying coil (and hence ultimately back to the sending coil) arrives at the sending coil one cycle behind the corresponding pulse that initiated the flow of electrons. This one-cycle lag of the back-force, as well as a corresponding one-cycle lag in the feed-back, enables small starting pulses produced in the sending coil to produce progressively greater electrical outputs each successive cycle. Consequently, assuming the electrical load is not excessive during startup, only a relatively few initiating cycles from the external energy-input source typically are needed for achieving production by the apparatus of an amount of output power sufficient for driving the load as well as providing sufficient energy feedback to the sending coil in a sustained manner.
tak
