Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Tesla is alive and kicking in the TPU!
So when Tesla drove a Tesla coil the device emitted externally.
Let's drive one backward and the device sucks in everything, right?
Lightning, RE, wind, gravity(thump, thump, thump).
Also reference patent 5,590,031 attached.
[9:11:41 PM] Dan LaRochelle says: it's basically a backwards Tesla coils, but the gauge of primary and secondary remain the same etc...
Jason says major kickage!
Thanks JDO300, Danswaay.
http://www-personal.umich.edu/~mssd/jed/experimental.html
Pay attention to wave lengths!
Suppose we make a Tesla coil secondary that is exactly one wavelength long, then suppose we wind it around a toroid instead of a cylinder, and when we are finished winding our coil we connect the ends of the wires and solder them (making one really large closed loop). Theory says that a full wavelength should fit nicely in a coil that is one full wavelength long (seems reasonable). Interestingly we could argue that the very same secondary coil is really two wavelengths long (or three or more) and if we drive the secondary at the right frequency this becomes true. With a two wave length coil we would have 4 voltage nodes and with a three wavelength coil we would get 6 voltage nodes (and these nodes will alternate in polarity as they must).
--giantkiller. We be running backward!
Geeks rule! Go forth and Build!
Quote from: giantkiller on September 04, 2006, 12:31:59 AM
In regards to Stephen Mark rings: Let's go back to basics. The first coil is 3", the 2nd coil is 6", and the 3rd coil is 17" in dia.
All devices have their electronics in the middle. The 3" and the 6" have lumps. The 17" has clearly visible drivers of some type in the center.
But if one were to have 4 AAA batteries to a two stage transistor ocsillator at 5k, one could achieve(with the right amout of turns) a step up transformer capable of the output shown. The device could be Telsa coil of some sort. The 6" and 17" are just bigger versions.
On another note:
In the 'Nicola Telsa' movie. The one that starts out with the shots of Niagra falls and the the statue of Magnetic Nic, himself. There is a tour through the museum in Belgrade and what is shown are the 3 steps to create a rotating magnetic field, which the movie never goes into. But the device is deceptively simple to make a magnetic vortex. This is one of those things that if you don't have it to play with you can't see the benefits. Besides, Tesla had big iron and copper to play with. A Tesla link: http://www.amasci.com/tesla/tesla.html
Anyway, on to further on...
I'd be willing to bet that if 3 rings were on and phased correctly to create a rotating tercerary field. My assumuption(if I am allowed) is that there is a field displacement. Yeah I know, unproven so why speak about it. If one coil exhibits gyroscopic torsion then why can't that be magnified, spun, twisted, angular focused changes.
What I am implying here is that we all have just glossed over so much of the pertainant information, me included. Guess there is just too much to learn, retain & deal with. The rabbits trails have just been reduced by a phenominal factor.
Many thanks to JDO300 for the last insight on reverseness. Just too cool! Finally.
Saskia asks 'Are you sure you have enough windings?'
Jdo300
"Since the speed of light always equals the wavelength times the frequency we can theoretically squeeze in lots of wavelengths but the rub (of course) is that you must use higher and higher frequencies - eventually your tank capacitor stops being effective and your primary inductor becomes a fraction of a turn in length (not very realistic).   Now Saskia�s coil appears to have characteristics that differ somewhat from traditional coils. For example, if we use a single primary and drive a two wave length configuration with four nodes of equal (but intentionally underrated) capacitance, we find that the spark lengths in the rear set are weaker than the front pair (nearest the primary) and that the spark length between front and rear sets are feeble. This trail of energy seems to indicate that a Saskia coil likes to recycle some of its bypassed energy without need of a hard reflection (much like a standing wave in a circular water tank). The picture at the bottom of the page shows a variation of the above mentioned where we drive two perpendicular nodes, the trail is less pronounced now but still evident."
God Bless,
Jason O
Dansway
"Now Saskia�s coil appears to have characteristics that differ somewhat from traditional coils. For example, if we use a single primary and drive a two wave length configuration with four nodes of equal (but intentionally underrated) capacitance, we find that the spark lengths in the rear set are weaker than the front pair (nearest the primary) and that the spark length between front and rear sets are feeble. This trail of energy seems to indicate that a Saskia� coil likes to recycle some of its bypassed energy without need of a hard reflection (much like a standing wave in a circular water tank). The picture at the bottom of the page shows a variation of the above mentioned where we drive two perpendicular nodes, the trail is less pronounced now but still evident."
TPU is backward Tesla Coil....
Regular T-Coil = Fundamental -> Harmonics
TPU = Harmonics -> Huge Fundamental...!!!!
Enjoy!
~Dan
turbo
hi guy's  :)
i also like the inwarded tesla coil only it is not segmented for rotation.
here is my new coil.
Jdo300
Hello Everyone,
You are probably all wondering what this is all about. The point here is that the TPU is an inverted Tesla Coil!
Think about this, we put in 60Hz through something like a neon sign transformer and step it up to high voltage. We then adjust a spark cap and tank circuit so that the frequency is stepped up to a few 10?s of kHz. This square wave is then injected into the primary which induces high voltage, high frequency longitudinal waves into the secondary coil. These frequencies can easily get up into the 100s of MHz if not more for a finely tuned coil. What I am about to propose here is that the Tesla coil is a resonant harmonic pump.
Normally, people think that the energy that produces sparks and lightning bolts is a fantastic display of resonant rise, but there is soooooo much more going on there! Check out this quote from the Research article about the Zero Point Energy patent paul posted earlier:
QuoteProposing to convert zero point electromagnetic radiation to electrical energy, Dr. Mead grapples with the high frequencies that may extend up to around 1040 Hertz. (To gain a perspective, gigahertz radar is only 1010 Hz or so. Visible light is about 1014 Hertz and gamma rays reach into the 20th power, where the wavelength smaller than an atom)
Guys, the fundamental frequency of the ZPE is:
10,000,000,000,000,000,000,000,000,000,000,000,000,000 Hz!!!!!
Wanna know how to ?officially? say this incredibly huge number???
Ten duodecihertz!
Soooo?.. That?s why they say you can?t tap into it. The frequency is sooo darn high!
But, that?s is, in fact, not the case. We don?t even want to get close to this frequency because we could easily create a black hole from the intense stresses on space.
What does this have to do with a Tesla Coil??
Think frequencies; think harmonics?..
What happens when you take one tuning fork, strike it, and place it next to other tuning forks that are harmonically tuned to it? They all vibrate as well. They vibrate because energy is being transferred through the harmonics. If this was not the case, then the smaller forks would not vibrate at all!
So lets bring it back home. Our normal, average Tesla coil, produces lots of frequency harmonics depending on how well it is tuned. When it is at its best, we have the great resonant rise that we are all familiar with, but there is something else happening. If we produce enough harmonics, we can actually transfer energy from the environment! Just like a set of tuned forks all in a row. Only this time, the smallest fork is always vibrating!
Now, of course, you may be thinking that there is NO WAY we can produce enough harmonics to reach up to 1040 Hz.
You would be correct in that assumption.
We don?t need to!! Every subatomic partical already does this naturally for us! Hence the name ?Zero Point Energy?
Definition taken from Dictionary.com dictionary:
Quote zero-point energy
?noun Physics.
Energy in a substance at the temperature of absolute zero.
So we know that all atoms have an energy level that we can not go below. We also know that all subatomic particles have a frequency. This fundamental frequency or energy cannot be dampened. So look at all the subatomic particles as mini ZPE transducers. SO all we need to do is resonate with the particles and let them do the conversion for us. The particles all have a fundamental frequency:
These particles have a defined spin and emit electromagnetic radiation all the time 24 hrs a day. Just read some of the many papers Tom Bearden wrote on the subject for more information on that aspect.
The point here is that the subatomic frequencies are much easier to reach through harmonic resonance than the actual ZPE frequency. Think about the particles as microscopic antennas just like the patent mentions!
Since we have 100?s of trillions of these mini antennas built into every single atom of our copper wire, why not resonate with them?
Nuclear Mass Resonance
Tesla talks about how he mass matched his coils to produce the greatest potentials?. Think about this, think about the above article, and then think about what you could do with a TPU?.
God Bless,
Jason O
