Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Powered by Attitude...
Batteries not included nor needed.
--giantkiller.
Mannix
Turbo,
Bottles will not need to be inside the ring It is only if ss is being used that it is important....thats why "its easier to use tubes...especially to begin with"
neat work!
Bruce_TPU
Way to go Turbo!  When my tubes come in I will call on you for help!  ;)
Bruce
HopeForHumanity
Searl comes to mind when watching those videos. Looking at those metal balls reminded me of those rollers. :o
Ron Paul is internet overunity: http://www.youtube.com/watch?v=vXnBZd4nyWk
WE MUST STOP THIS! Free energy is being surpressed because of it!
