Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 41 Guests are viewing this topic.
shuzammy
I'd pay for a wound-to-spec Rodin coil.  =)
Rosphere
Quote from: shuzammy on May 04, 2007, 11:36:45 AM
PM me the particulars.
One, or several, wound by hand will be faster than making a machine to do it, no matter how simple the machine.  The larger the order the more the need for automation.  How many do you want?
[Tweaks 6 through 12 added above.  Others further clarified.]
(I appear to be avoiding my garage cleaning assignment.)  :(  ;)
Rosphere
Enough of post-working TPU mechanical coil winders.  ::)  Let us get one working first.  8)
I finally have both channels of my scope working.  Now I can ask questions like:
Does it look like my function generator, top, is making the right signals through my MOSFET, bottom?
(Both are working off the same 9V.  No coils attached,... yet.)  ;)
(Oh, attaching a battery to that top receiver flat lines everything.  Silly me.)  :D
innovation_station
hello all
i have returned after a long power outage
just wondering if many of you studied the picture in this link
http://www.overunity.com/index.php/topic,1872.970.html
also if you have studied this picture what might the scribles in the top right conner of this pic be?
i know what they are and this picture is where i got my tpu from
i will be adding a few more pictures of my tpu wired up as the pic says
also i will draw a simple picture on how it is wired and post today
check out the link it will be worth your time
also the schem has been here for a loong time humm... why not look hard at some avitars
i think you will see somthing also i will be talking about what i have found since i started this project not so long ago
with the info on this site how many rings do you all think have been built and are working as we speek?
i know of none personaly but im sure that there many many working right now i can say that if i had more electronics experience i would already have many rings up and running and i would be designing new styles of rings but i dont have the experience so i have to take it 1 step at a time
if you notice there is almumnim plate on the bottom well heat sinks in side on the bottom ring or fets and floating magfeids triping the fets
about the 3 collectors inside the control windings this is what i think
bottom ring input and control wire are hooked togather output of bottom ring goes to input of second ring and also to the control wires on second ring but where the wires connect for the 2 mag feilds and then the same on the top collector then i think this is where the fets come in top and bottom and they turn off and on the coils and i think that when the fets are off you get your hi voltage kicks  and then the fet sends the hi voltage kicks through the output windings  i think that both fets do this when they are not sending freqs through the wire and that is how you tap your  kicks and feed ing a small voltage in to start the turbine and it grows every time it cycles through the rings and the reason it does not work when you turn it upside down is because youe bottom ring must be negitive and as it rotates with the earths magnetic feild the earths magfeild makes the 4 ring because the top 2 rings are positive and the bottom is negitive and the 4 is the earth
but agin i am guessing this is not proven altho im getting a fair bit of current out of my ring with just constant power in hooked up only my control wires and 1 collector
is
