Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
innovation_station
hello all
has anyone tryed to put a super cap above where the magfeilds colide? i think that it might charge the cap and if the fet was put in another magfeild collision point when the feild colapises it will trip the switch the fets will use the floating feild and the caps will capture the engery and then frie back into the system it could all be started with a small amount of electricty posibaly a permant magnet to charge the caps for the first time or a swipe or 2 or 3 from a magnet to induce a voltage in the system the wind up or turbine effect or ramp up time is when the coil is building up its power
just thought i might share those thoughts with everyone
about my wireing just look at the link i posted earlyer it is on that page i tryed to draw it but im lously at it i still have not finished my tpu i was wireing thats why i have not posted any pics yet
i am building  a new 1 soon agin this time i will use thinner mag wire and fater collector wire still 3 rings but only 1 outer collector winding i will use 4 ga car audio power wire for my collectors and some realy fine gage magwire 30 or so gage for my controls
i thought i might add just a few more thoughts
this is what i see happining in the tpu and only a basic description
well we know we need to rotationg mag feilds in 2 dirrections 1 + and - or 1 2 1 2
and then they will cancel the flux of each other
we also need a generator or a particial accelerator  that we keep dumping back into its self  also caps and fets then we also need the right freqs to make the control coils ring and when they ring they produce a lot of kicks and those kicks are output i think that the inner collector is only to power the controls after you start it and the outter winding is out put for load when you smak the magfeilds togather it makes a a few diffrent things happen all at once
when we look at this picture might this be how it works ? carry the pattern all the way around the ring oc stands for output collector  and if you had 3 rings stacked and hooked up the way it says in the pic i posted the link to all the control wires 1 and 2 would only have 2 wires comming from it top and bottom and if you plused 1 freq in the top and 1 in the bottom to make a beat freq and if they harmonized with the freq heeded to make the coils resonate there would quite a magnetic disturbance inside the ring but we are cancling the magfeilds also there are many many kicks going it to the inside collector and many going to the outside collector  the inside collector starts powering powering the control wires adding more input power to the magfeilds each time it makes a revelution through the coil does this seam right to anyone??
is
Rosphere
Well, I, for one, am a bit frustrated with my lack of any real progress here.
Winter is gone.  I am spending far too much time in the house and I need to get outside in the fresh air.  I may be back in the late fall when the sun goes away again.  :-\
Later taters,  ;)
Rosphere ==|--------
Motorcoach1
Interesting efeccts - I was looking into the SM large Tpu and set up a SS box and wound some small coils i posted one a while back . on the big rind i just took 2 steel wire in a ring fasion and wraped a small copper wire at 45 degrees - then i had some leaf pladium taped to the wires ( this is a very thinn metal -lite as a feather) when i turned on the SSbox with the 2 small toriods it was like a solor wind on the ring mmmm now thats cool - what properties are at work here.   I didt this to see if the 2 small toriods developing oppisit spinns would vortex mmmm simply not , but what i did surmize was that the spinn of electrons were crashing into each outher and splitting off.ok heres the cool part - if it is and electron then the pladium would flow to the outside of the ring and if it was a protron it would flow to the inside of the ring and turn up. At diffrent frequenzes they would shake like leafs on a tree and some would do a dance then in flow in a graphic sequence. dam is this some fun stuff . just thought I'd share this with you ...Mike  small things keep me amused
