Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
devilzangel
@Jdo300 .. have u tested the 1/4wave=Circum. theory on a TPU to see any significant results?
devilzangel
mkt3920
In reference to the possibility of the CONTROL coils being stacked one on top of the other, remember this Mannix/SM quote:
<quote>
You know, it is very similar to the idea of a long garden hose. Picture a hose with water in it. If you pick up one end and move along the length of the hose you will move the water constantly along in the direction you are moving. You could also squeeze the hose in the direction to move the water along as well. And you could do both to control the movement of the water more precisely. You can think of the movement of water as the movement of electrons through the collector coils. <unquote>
Kent
mkt3920
To me, this picture looks like two different CONTROL coil wire sizes, maybe one on top of the other.
Kent
turbo
hi guy's the first control circuit i build was a simple 3 channel sequencer to see if i could get the field to rotate.
it simply pulses coils one after the other.
it's no good because it did not work well but i think the coil construction is wrong so i will keep the circuit to test with other coils.
Turbo.
giantkiller
This brought forward:
Thanks LancaIV.
http://www.overunity.com/index.php/topic,1761.msg21125.html#msg21125
IN. RI veritas est,
(Ma-)Rio Pasichinsky,US 4904926
http://www.pat2pdf.org/patents/pat4904926.pdf
S
  dL
p.s.: the next step US 5568005, Dan Davidson
http://www.pat2pdf.org/patents/pat5568005.pdf
What I see here is the SM15 - SM17 central control unit. Then the outer rings are a bigger version of this. Don't worry... We got feedback.
This brought over from elsewhere...
http://www.overunity.com/index.php/topic,2235.msg30771.html#msg30771Quote from: otto on May 04, 2007, 09:51:34 AM
Hello all,
Ok, now its really enough!!!
1. Tesla patent 390721
2. Mobius strip or band
With this informations you have my biggest help since Im posting here.
Otto
I followed Otto's jumpering for the GK4 coil. This configuration is harmful!
Here is validation of an experiment to produce power in the Hi-RF and Microwave ranges:
http://www.overunity.com/index.php/topic,1872.msg21431.html#msg21431
The previously mentioned frequencies are below Radiant Energy transmissions.
http://www.overunity.com/index.php/topic,1914.msg22312.html#msg22312
http://www.overunity.com/index.php/topic,1761.msg21120.html#msg21120
The fast rise and fall time in the pulse send a very wide range of harmonics through the copper faster that it can produce a magnetic wave. Hence the discharge.
Otto said no iron and Starcruiser said caps instead of resistors. I have not tried either as of yet.
Since January 3rd I have tried other more dangerous things, i.e. stunguns. I need to cool my adventurous jets a tad.
--giantkiller. It do work!
