Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Moab
Quote from: turbo on May 08, 2007, 01:46:26 PM
also he said:
When I accidentally stumbled on a device
[/b] that appeared to actually pull electrons from the sky, it  was the ONLY working model for many months.
I showed the thing to people and eventually got enough interest to get money and other engineers involved to crack the code so to speak, and be able to make more of them.
After I had the first operating unit I kept trying to make another one.
It took me many many many
tries just to
duplicate
the same unit and make it work!
I thought of everything... why couldn't I make another one that would work?
I decided that there must be a few more turns of wire in the collector etc. [/i]
so definatly not one turn...
He says he stumbled on it, Hmmm.. Thats why he says over and over in the vids he has no explanation for this or for that.. He didnt envent the damn thing? If thats the case where exactly did he sutmble upon it?
like,, So I was looking through this box of what i thought was junk and i Stumbled ON this devise.
Or. I was out with the guys and woke up with this devise under the seat of my car, Just setting there, I have no idea where it came from?. Wtf does that mean exactly?
                                           ???   M   ???
turbo
this means he discoverd the reaction...
then he build the first working device and my guess is it putted out more power then he expected.
then he improved the design over and over.
so i don't thing the thing was in a box and i don't think he found it somewhere.
Turbo.
gn0stik
I think he was more likely messing with things that audio engineers of his particular generation who were interested in recreating PURE perfect sound messed with when he found the effect. Kind of like how cavemen stumbled upon fire long before they knew how to make it. They'd seen fire before, obviously, after storms etc. But one day, a guy TOUCHED some fire and a few neurons fired, and he thought of how damn sick he was of being cold all the friggin time.
So question is, what was he messing with? What are the possibilities here? Well He's told us. First, TUBES.
QuoteI found the secret when I read in some books about electron tubes. I was a TV repair man as well. Back in the days of electron tubes. The good old days I think.
In one of the RCA engineering manuals I read that it has been measured in a wire that there exists a slight increase in current when first electrons are caused to flow in it. This was explained because the earth's magnetic field exerted some influence on the wire and the electron flow inside it, or rather the electrons on the surface of the wire.
Second toroidal transformers.
It is an insignificant power supply except when the two transformers get slightly out of phase with each other, or when they are connected in reverse of one another. Then you can measure all kinds of things going on.
I became interested in the interaction between the two AC transformers. The interaction can be very reveling, trust me.
QuoteYES, toroidal transformers have some very weird factors.. Study the strange factors.
So Tubes, and transformers out of phase, somewhere between tubes and SS were mag amps, and they might be of interest as well. The point is, that SM was an audio engineer, thinking audio engineer thoughts when the lightbulb turned on. Perhaps literally.
Regards,
Rich
turbo
"When I began to study the effects of multiple frequencies combined together I found out that when you deliberately strive to create the worst case scenario of frequencies you start to get some very measurable kicks.  In themselves they are not much. But if you make enough of them fast sendoff, you get a collectible power spike that is more then the power available to begin with".
he was also creating spatial audio effects using white noise, which is in my opinion the worst case scenario of frequency's.
then i was reading about lightning somewhere,
How do you tell if there's a thunderstorm nearby? Just turn on the AM radio to any station, and you should be able to hear blips, coming from flashes of far off lightning. AM radio works better than FM radio as a lightning observatory, as it is more susceptible to noise than FM.
For a regular pulse train, the magnitude of our side frequencies will go up and down, decreasing slightly each time until they reach zero. Lightning, however, is a special case. The side frequencies will be 0 hz apart, and equal to the fundamental in magnitude! What does this mean? Lightning is an AC signal of 0 hertz, with side frequencies stretching off into infinity, all with the same magnitude as the original signal, i.e. White Noise, omnipresent on all frequencies at the same time.
Lightning can be described as a pulse train, much like a square wave, with a frequency of zero, and a duty cycle of zero.
"The key to the kick's strength and appearance was in how fast Tesla discharged the capacitors into the spark gap AND how fast Tesla STOPPED the flow of current AT the spark gap.  Tesla used all types of devices to stop this flow of current, magnets, a flame, counter-rotating engines.  His goals were to get the time in which the discharge is STOPPED to be much quicker.  As Tesla did this he found that the perpendicular radiations, the ones from the wires, caused electrical effects to appear in wires and other copper/metal materials near the STOPPED current/discharge.  These electrical effects could be made to create electrons on other wires and copper around his STOPPED current/discharge wire".
hmm  STOPPED, STOPPED, STOPPED, STOPPED....?
weri812
  go!!!!!!!!  TUBRO
very well said
you would think that every one would try to build a small working modle first.
then move on to a big one. has any one  have a small working modle???
if they do  they need to pm  other on how to get one to work so the rest can
be on track.  togather we stand  divided we fall !!!!!!!
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
