Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
mrd10
aether22
Ok, I suck at making circuits.
There are several reasons I haven't tested my almost completely build TPU (v1, GK's design) and most of it comes down to troubles with the 555 circuit, I solved most of the problems but 1 remains.
When I have any one of the 555's on it works fine, but when I turn on 2 or especially 3 they somehow interfere with each other.
Now this may be because I don't have a small value cap between pin 5 and GND, but I figured as everyone here has built this circuit, you should all know how to fix it.
So has anyone else had this problem?
AhuraMazda
I guess you are using the same supply for your electronics as the coils. I suggest you feed the circuit either from a separate supply or feed the existing supply though a diode to a 1000uF capacitor and feed your circuit from across the capacitor.
AM
aether22
Nop, no coils even connected yet, was just checking out the 555 circuit.
If you have not had this problem, please indicate if you put the cap on pin 5 and ground. (it will be a bit of a pain to add this 'optional' cap so I'd rather establish if it can possibly be the cure)
pese
@aether
the dc line  also transfer the frequencies to each other 555 !
"decoupling" this . each 555 "hook up" elektrolydt 10-50mf also
one 0,1mf (ceramic disk or foil-block)
if possibel connect al - (minus or grund points of IC (even ALL other in- and outputs)
to an SINGEL point !!!
(1mf = 1uf)
pese
