Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
turbo
however, if we think about firing a pulse into a coil and stopping it before it reaches the end...the frequency would indeed depend on the circumference of the coil/ length of wire/number of turns/voltage.
RE weekend comming up 8)
Turbo
MACEDONIA CD
HI     I WHANT TO SY THIS  I MAKE  THIS  DIVICES  I LIKE  THE TURBO  DIVICES   WHIT  9 VOLTS  ,, THEN  DIVICES   IS GIVET  MORE POWER  THEN INPUT   ...ITs  like this  ,,,first i  make  osciloator  whit  driver  mosfet  BUZ 11A   THEN  I MAKE  6" INCES  TOROID  COIL    WHIT  18 TURNS THEN I MAKE  AROUND  WHIT THIS COIL   I MAKE  26 TURNS  IS LIKE  TURBO  VIDEO CLIP  ....MY OSCILATOR  IS CHARGER  WHIT  11WATS   AND  THEN  I THE  COLECTOR COILS  I HAVE  MORE THEN  25 WATS    BUT  I THING  IN THE TURBO COIL  IS BRING  1 FRECFENCE   WHIT  1 MOSFET TRANZISTOR   THE ATHER  2 TRANZISTORS  IS  FOR  THE CHARGIN THE  2 CAPACITATORS  ,,,  FRIST   IS RECHARGIN 1 CAPACITATOR  IN THE BULB   IN THE SAME TIME  IS CHARGIN  THE ATHER ONE CAPACITATOR     I
IF  THE TURBO  NOT A HAVE 2 CAPACITATORS  THEN THE BULB  WHIL LIGHT  ONLY  I 1 TIME  NOTHING ELSE    BUT  THE LIGHT WHIL THE  MORE POWER THEN INPUT  HO IS CHARGING  WHIT A  9 VOLTS ...
  ITHING  THAT  IS THAT     THE NEXT TIME I WHIL E SEND  VIDEO    CLIP  ..
AND YOU WIHIL SE E  HOVE IS THE MAKE  HAPEN THIS MORE ENERGI THAN INPUT
MANY THANKS  FOR Macedonia
thi is my email   <<<<<<<<<<  cede74sk@yahoo.com>>>>>>>>>>>>>>
innovation_station
Quote from: dutchy1966 on May 11, 2007, 01:17:05 PM
Remember that in the open tpu there is a tv flyback transformer!! This points to high voltage being used! Question remains what is being done with it....
Robert
it has to be going through the upper and lower collector and spattering out because of the gage of the collectors only certan freqs are rated for certian wires so use a wire it will spatter from  to the center collector through plasma or sparks or somthing else
i have a new idea on how it is all wired
this is my most receant thought on how it is wired i think that you start from the out side like my last ring send power through all the wires except the center collector my controls are all 1 wire  so power goes through the outter wrap first then the inner wrap then the controls then the bottom and the top collector that way you have a verry long wire and when it gets almost to the end it is in the collector and it will spatter as well it is seting up a cancleing mag feild all the way around the ring from the outside in and "squeezing the hose" in a 3d way putting more power back into its self on the way to the collector to spatter and if we put a final wrap of steel wire on the bottom and top collector the electricty would jump through a gap to the center
more new thoughts
is
Grumpy
I've never gotten a good explanation of the three frequencies.  It can be taken too many ways to really discern what the hell SM is talking aobut here.  I can surmise from the fact that there are three collector setups, then each would have it's own natural frequency (for the control coils that is).  This would also imply that even with impulses - each would have it's own freq that it would work best at.  Tuning for longitudinal is very high Q - very touchy - this is in line with many things SM said.
As for the outer wrap - who knows - maybe it is just DC in it.  Damn thing could be shorted for all we know - seriously.
Or, he vibrates the collectors at one freq, the control coils at another, and the outer wrap at another - who knows.
Does it really matter how SM wound his wire?  No.  Take what you know of RE and  - get the charging effect first - and then proceed.
        -Frank Edwards
giantkiller
@IS & Macedonia,
Great ideas! You'll see that the GK4 is not high power and fully documented to try.
There are other coils that work, but this one is the most publicly expressed. This is not the most powerful but it is the nastiest one fully disclosed. 2 others have tried this one and chose not to talk about it publicly.
The GK4 is an open face microwave transmitter. It also produces radiant energy. I did not pulse it in the orginal way and use the stungun in parallel. Too dangerous!
The LOTR:1:2 post shows that I used all coils with frequencies in them.
Attached is the next build of a similar version of Turbo's last build.
I have made a few differences. The collector is 20 turns of 30 feet 30awg. Should the unit go runaway it will self destruct. I am going to use my GK ring counter circuit also with modifications. I will place an opamp at the end of each of the 3 segments. This will cutoff that segments pulse via a reset at the 74ls193 counter. The rise time will be taken into affect. I could use that to pulse the next counter stage to drive the next segment also.
The control coils are 3 segments of 8 sections. Each section is 40 turns of 30awg. Each segment will consist of a single wire. A radio shack spool of 30awg 200 feet should fill the whole ring. That will equate to 3 phase 24 field motor.
4 1/4 inch diam sched 27-29 thin wall,
1 inch high but the coil space in middle is 3/4 in for coil loop height.
New and imporoved! Now with full controls on. Less than 1 spool of 30awg wire. Can you say 'A buck fifty?'. Radio Shack corporate must be scratching their heads. Terminal blocks and wire sales have jumped up in the last months! Ship more wire!
Next I do the top and bottom Helmholtz coils.
1st Helmholtz done. 10 turn awg 26 stranded with 6 inch leads. Time: 10 minutes. Somebody, stop me! :D
Final answer. Think Helmholtz. I see 3 sets of 1collector and 1 controller. 3 controllers? Yep. One per layer. I can do 3 per the middle collector if I want. 3 frequencies? Yep. 3 pathways for the 1 frequency to go. This thing is inbred. I see mobius Hemlholtz's. There are actually 4 or dual middle current coils. The gold winding on each actually modifies the field of top and botom collector coils. They would be feedback. Any reason why it looks like snare drum?
Total build time was 3 hours.
Now I go to bed and sleep this TPU drunkeness off. Probably wake up with same day hangover.
Tonight I will jumper this one. I will call it GKMTC1(giantkiller modified Turbo coil1). Compact little dude, eh?
@Motorcoach1,
"One Ring to rule them all, One Ring to bind them,
One Ring to bring them all and from the darkness find them."
--giantkiller. The ringwraiths are loose! ;)
