Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
UncleFester
Quote from: gn0stik on May 14, 2007, 09:38:48 PM
Quote from: innovation_station on May 14, 2007, 07:16:42 PM
@ gn0stik
whats the deal with the probs are they special can you not replace the tubes if they are blowen shipping and the generator would probaly still cost you less than you are going to spend on 3 ss units that i think you will have a verry hard time getting them to work for you. will you not? steven said tubes to start with and what if you only need 1 generator?
Have you seen a SM video with a TPU which uses tubes?
Have you built a tube based circuit before? Let me tell you, it's a royal pain in the A$$!
The cost of solid state electronics and their accuracy cannot be beat. I'm not talking, 555's I'm talking microcontrollers. This is why the entire world runs on solid state silicon based technology. On top of that, the cost of tubes are 5-10 times the cost of solid state electronic components.
Also, back in the day, Mannix suggested we all build max038 gennies which are of course, solid state.
The effect can be found using solid state, but may not be able to be sustained without proper protection, He says in one of the videos "sometimes they wouldn't even start." Or was that a quote from a post.
@Mannix, what were the results of your tests with the Tube amp that you built?
Regards,
Rich
If this thing is going to work, it's going to be on solid state electronic devices. Don't worry about the tubes Gn0stik, leave them for the others who have more time and money to put down the drain.
I'm now putting out a $500.00 reward for anyone who gets a TPU to work on tubes and yet cannot get the same TPU to work on Solid state electronics. And when I say work, I mean 50+ watts output on the collector and half or less input power to the control coils (25 watts or less).
Jdo300
Hello All,
After getting the positive results with my trifilar coil test, I have started on my Helmholtz, bobbin TPU test stand. I will be taking Grumpy's suggestion and will wind 200ft of 30 gauge wire for each control coil. Conveniently enough, the 30 gauge spools of mag wire you get from RadioShack happen to have 200 ft of wire on them. So, I'll just use three of those for the three control coils. For my center collector, I'll use segments of speaker wire (the same red stuff I used for the last coil). More to come :).
God Bless,
Jason O
giantkiller
Dude! That is TPU LEGOS!
I hope that isn't a patent infringment.
--giantkiller.
innovation_station
@unclefester
if it runs on tubes you can make it run on ss it will be a lot easyer to make it work with tubes because you can use a tube generator for many rings and a scope to what happins when you hit the right freqs after you find out what the #'s are for the ring  you can then build a simple cricuit that only produces the freqs you need for that ring thats what i see any way take what i say as you wish
just my thoughts thought i might share
is
Grumpy
3 freq's, 1 per ring (collector) to make the current flow so it can be amplified - took a long time to understand this and I'm still not convinced this is all.
SM also stated that you could use the same freq or different freqs.
Comparing outer wrap to segments = air-core induction coil.  Coincidence?
JDO300 - 200ft - yeah baby!  Now try the rest of what the message laid out.  High freq pulses, no ring, no return current.
Back to the cave...
        -Frank Edwards
