Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 121 Guests are viewing this topic.
Jdo300
Hey Grumpy,
Yeap 200 ft for each coil! I did some calcs and determined that I would have to wrap 100 turns in each slot to fit all that wire into the 8 slots for just one control coil!. I also agree with you about the high frequency pulse.
I believe that I have found the ultimate TPU pulse circuit! It?s called a blocking oscillator:
http://en.wikipedia.org/wiki/Blocking_oscillator
This is the simplest pulse circuit I have ever seen! Only four components for this thing! And the best part is that it is specifically designed to make very short, high voltage, pulses, which is what we need! All you need is a center-tapped transformer, cap, transistor, and pot to adjust the frequency! I?m still playing around with this circuit to get it to run. The beauty of this is that we don?t need a function generator at all! We simply tweak the pot and the cap on the transistor to adjust the frequency range. But wait, there?s more! This circuit can easily be adapted to use tubes! After doing some reading on the oscillator, I found out that it was commonly used in the old tube TVs to control the vertical and horizontal retrace speeds for the screen! Makes me think more about the exploding TV example? What would happen if we have two frequencies in the TV along with the DC field from the yoke and something happens and one of those tubes makes one two many harmonics?.. BOOM!!
God Bless,
Jason O
gn0stik
Quote from: UncleFester on May 15, 2007, 09:04:22 PM
Quote from: gn0stik on May 14, 2007, 09:38:48 PM
Quote from: innovation_station on May 14, 2007, 07:16:42 PM
@ gn0stik
whats the deal with the probs are they special can you not replace the tubes if they are blowen shipping and the generator would probaly still cost you less than you are going to spend on 3 ss units that i think you will have a verry hard time getting them to work for you. will you not? steven said tubes to start with and what if you only need 1 generator?
Have you seen a SM video with a TPU which uses tubes?
Have you built a tube based circuit before? Let me tell you, it's a royal pain in the A$$!
The cost of solid state electronics and their accuracy cannot be beat. I'm not talking, 555's I'm talking microcontrollers. This is why the entire world runs on solid state silicon based technology. On top of that, the cost of tubes are 5-10 times the cost of solid state electronic components.
Also, back in the day, Mannix suggested we all build max038 gennies which are of course, solid state.
The effect can be found using solid state, but may not be able to be sustained without proper protection, He says in one of the videos "sometimes they wouldn't even start." Or was that a quote from a post.
@Mannix, what were the results of your tests with the Tube amp that you built?
Regards,
Rich
If this thing is going to work, it's going to be on solid state electronic devices. Don't worry about the tubes Gn0stik, leave them for the others who have more time and money to put down the drain.
I'm now putting out a $500.00 reward for anyone who gets a TPU to work on tubes and yet cannot get the same TPU to work on Solid state electronics. And when I say work, I mean 50+ watts output on the collector and half or less input power to the control coils (25 watts or less).
12ax7 tube amp build instructions
http://www.allaboutcircuits.com/vol_6/chpt_5/19.html
Feed this with my fucntion gen, best of both worlds, and looks pretty brain dead easy to boot.
Just sayin...
Rich
gn0stik
AND if it doesnt work I can plug my git into it. Or my daughter's bass.
So no big loss that way either.
What I'd really like is a triple head square wave gen like vortex built. I don't think I'm quite at that level though.
Rich
Moab
From Wiki
Some cameras use a blocking oscillator to strobe the flash prior to a shot to reduce the phenomenon of red-eye.
Give anyone an idea?  remind anyone of Gk's stungun?
giantkiller
I've had red eye for months over the stungun test into GK4. Yes, the blocking oscillator is not new. The stungun circuit i posted is a blocking oscillator with an on board sparkgap as an energy transmission step. After reading the circuit diags and seeing sparkgaps in other men's circuits I realized the stun gun people have no idea of Radiant energy. By putting the ezflow on the output probes i actually extended the range of the radiant energy tranmission to a more destructive level of emmision. All from a little tickling oscillator. The stun gun actually has steel cores in the last coil to limit the radiant emmisions. By putting the ezflow on the end you bypass this dampening. I believe I am on Tesla's coat tails here and have been for months.
I already applied this to the coils and saw a whole bunch of stuff. I did not post the half of the results because of the terrorist implications.
Gnosis posted that there was alot of excitement over my Turbo coil reproduction but no electrical tests. The results were back in Jan 3-2007 when I got the physical damage from close proximity to the coil. Not everything is as it seems. I have been holding out.
I never claimed to find anything new and I never claimed to be the first. I only followed the clues, instructions and directions from the topdogs of this adventure. I repeatedly have stressed safety and showed unsafe results.
I now know why the secrecy abounds. For safety. But in the same vein when I found out something I got excited and ran to the end of my leash only to get yanked back into the reality of group think. I could not nor can I devulge these things.
So keep your pride and exhuberance at an even keal because the one next step you make could put you or others in danger. The dangerous exhibitions I executed months ago are waiting on the shelf to be turned into products. I stressed months ago that the Tesla coil is an advanced stun gun ckt. The TPU is also and advanced stungun ckt. Refer back to the ezflow experiment.
I speak these words in truth. The cat is now out of the bag with Ottos jumpering on the GK4. Phase cancellation has been happening all along. This was the one step that now answers alot of the questions and mystery. After the GK4 tests were posted all the topdogs were on me immediately. And I mean 'everybody'! Otto was the only one to tell to 'Not use Iron'. There is a clue. Now this step has all copper collectors. Shit, somebody is going to get hurt. How are you going to explain to the authorities about your current accident where the flesh has been completely blow off the bones of one of your lower arms or a hand is missing? Don't laugh. We have all seen the popcan exploding. You could reach into the ring to move a neomag and Bam! You just lost 2 fingers! Moab had to go to the hospital for burns. How would you like to see a plasma ball disappear into your arm only to burn you from the inside out? What about the kids and pets watching the little blueish fairies flying around the room?
Also there have been posts in the past about me babbling, incorrect sentences, missing words, un connected thoughts, totally comical retorts. I tell you this now, that at the time I could not begin to explain in detail now nor will I about the major results or fears of what I found. In this project all my dreams and nightmares have come true.
Heed this warning...
--giantkiller. I am as sane as ever, just more cautious.
