Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
CTG Labs
Quote from: AhuraMazda on January 14, 2007, 12:48:27 PM
Dave,
Have you seen this:
http://www.overunity.com/index.php/topic,1761.msg21389.html#msg21389
and
http://www.overunity.com/index.php/topic,1761.msg21397.html#msg21397
AM
Hi, thanks for the references, I had read them before also.  I did hold a small magnet nearby and could feel it vibrating, but what do you expect when you hold a magnet inside an oscillating field!  Although I cannot say if it was somehow vibrating faster than the applied frequency, how can you tell?  Perhaps wind a coil around the magnet and read out the frequency on a scope?
Well I will either build a 555 timer circuit which has 1-100Hz so its much more fine tuning or I will hook my signal generators x 3 to some transistor drivers and see if I can anything then.
Surely if the transistors are in full saturation have no voltage drop across them, then they could well remain cold while the higher resistance coil gets hot?
D.
mrd10
No problem D, I was only trying to Help
Sincerely,
Dom
aether22
I have also built and tested my GK TPU, though I haven't tested it much.
The insulation on the wire I used was crap (It must be an awfully old spool of wire, like ancient, or it must have been heated, I won an internet auction) so there is a short between 2 on the control coil layers.
Because of this I am reducing the testing of it to 'quality time' before it gets any worse.
GK, I seem to recall you mentioning that it reversed the earth magnetic field, now if that's what you said, that would be a great test to try.
Though as the coils are wound on steel with opposing fields I would expect significalt external magnetic fields so are you sure it was indeed reversal of the earth magnetic field?
If it is true reversal you could of course turn the TPU and the compass needle shuldn't budge.
Otherwise please explain exactly what I need to do to see something because I fear it might not last for long. (and with control coil layers shorted together as is it simply may not work.
giantkiller
Quote from: aether22 on January 15, 2007, 11:30:15 PM
Hi,
When I got the new pots I went back and retested that. I am incompetent. I didn't right it down. Was doing too many tests. I can hook it back up tomorrow and see. Sorry about the short. I am working on GK5 at the moment and am testing it on my controller. Sorry. I am just moving ahead too fast. Remember this, without kicks you don't tune. And above all else, you want to get there. ;)
--giantkiller. You gonna post a picture of your monster before the towns people torch it?
Talk at ya tomorrow.
aether22
It's Camera shy, sensitive about it's hair. (I just have the wires going everywhere)
I'll post it soon, but please don't point and laugh.
