Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Dansway
A ring modulator accepts two inputs and produces the sum and difference frequencies of them.
For example, if two sine waves of 100 and 150 cycles are present at the inputs,
the output will consist of two frequencies 50 cycles (150 minus 100) and 250 cycles (150 plus 100).
Waves with many partials, such as rectangular or sawtooth waves, create very complex output signals.
Ring modulators offer a convenient way to create metallic sounds, bells and klangs.
They have been widely used in the creation of electronic music.
This Ring Modulator design is very old and unique.
It requires no external power.
http://www.synthfool.com/ringmod.html
Bruce_TPU
Quote Of UncleFester:
"But we aren't crushing cans or shrinking quarters here, nor are we trying to amplify music. We are simply pumping coils with a square waves and need VERY precisely controlled timing."
"nor are we trying to amplify music."  hmmm... I wonder..
SM's Words:
"Gee, why not just build a tube amp to begin with.  Less distortion and little need for feedback overdose.  Much faster all around."
And:
"I have designed some Amps using MOSFET, etc. Which sound very much like tube amps.  However when I want to design a new AMP, I always start with tube and then move on the MOSFETS..."
And:
"lamp cord is what I use to connect my speakers (collectors) to my AMPLIFIER.  You should hear my new amplifier I have made."
AND:
"MOSFETS are better you if you wanted to make an amplifier that BEHAVED like a tube  Amp but in a smaller size.
I know every one here knows all of this, but just thought I would throw a friendly reminder to those who may not.  ;)
To SM, modern King of electrons,
Bruce
UncleFester
Quote from: btentzer on May 16, 2007, 10:06:01 PM
SM's Words:
And:
Woohoo! Musical TPU's! LOL! If only it were as easy as playing a little mozart through a tube amp into a control coil and getting massive power out the other side. Man, that would be sweet!
P.S. I'm starting to believe that SM had little to do with inventing this device and rather some heavy hitter engineers were probably involved. Maybe he was more part of the marketing of the device and knew enough to show it and explain parts of it? Who knows, whatever the case, we are still missing a major amount of details......
nong
