Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Bruce_TPU
"whereas the superior electron cascade effect creates free-electrons actually in the environment by speeding up electrons, which in turn collide with air atoms, to create more free-electrons."
Jason,
The above is from the link you posted.  The air atoms that are being collided with in the collector are not regular particles.  I have an entire post nearly finished, for tomorrow, dealing with pressure waves caused by amplified sound and their affect on air molecules within the collector.  But this fits so well I had to add my two cents.
But if this is true, where does it leave the whistler wave?
But if this is true, it might explain the AC 5000 HZ in one of the engineering reports.
But where does the whistler fit If it is High Freq.  Could this same process be done at 8 Hz?
Thank you for your time,
Bruce
Bruce_TPU
Let's say that we are wrong for a minute about the whistler wave.
The Ionizer is using static electricity to clean the air.  Could that be the answer that fits the Tesla clue and the magnetometer going off the chart..
"Static electric fields occur naturally in the atmosphere, particularly under thunderclouds, and can lead to lightning strikes"
Perhaps it was not the magnet wave around a thunderstorm, but rather the cause of that wave, being the static electricity.  No lightning, no magnetic field, no magnetic field, no Tesla mangetometer going crazy.  Just thinking aloud!
A very good link that clears up misconceptions about static electricity
http://amasci.com/emotor/stmiscon.html
Jdo300
Hi btentzer,
I am not sure exactly how the whistler waves would fit into this explanation as I have not really considered them in my TPU theory. I know others have talked a lot about them, especially with respect to the magnetic reconnection thread over on the Gn0sis forum.
I do agree with you that in the case of the TPU, we are not accelerting air molecules, we want the electrons from the air molecules (or juat any free-floating electron in the atmosphere). They are all over the place riding on the flux lines of the earth's field coming from the poles onward. I have no idea how many free electrons there are at ground level though. That would be a good thing to look up though.
QuotePerhaps it was not the magnet wave around a thunderstorm, but rather the cause of that wave, being the static electricity.  No lightning, no magnetic field, no magnetic field, no Tesla mangetometer going crazy.  Just thinking aloud!
I absolutely agree with you here! This is exactly what happens in a nuclear explosion that causes the intense EMP burst. When the gamma rays knock off all the free electrons, and they get accelerated back to the cloud, their acceleration produces the huge magnetic boom. So now that I think about it, we may not need to actually capture the electrons from the air molecules around us at all. Perhaps all we want to do is jar them enough to accelerate them so that they all produce a large magnetic wave that can be 'collected' by the collector coil. This explanation would seem to fit the magnetometer explanation nicely. This explanation also lines up more with Steven's explanation of the kick being the result of the "earth's electromagnetic field" contributing some energy... Maybe that is simply the electromagnetic field induced from the atmospheric interaction?
God Bless,
Jason O
Bruce_TPU
What voltage and what frequency are you thinking?
My guess, try 5000 Hz, but I have no Idea about the voltage.  How much is required to start the reaction in the air cleaning device?
If you look at that thread I posted, It has some info on high voltage use and static electricity that may be useful to you
We can leave no stone unturned,
Bruce
giantkiller
