Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Bruce_TPU
Hmm..Kind of looks like three collectors, the center one not have any high frequency voltage.
Motorcoach1
giantkiller
Just testing my new domain name and email address...
Looks like it works quite nicely.
--giantkiller.
Jdo300
Quote from: btentzer on May 19, 2007, 04:33:30 AM
What voltage and what frequency are you thinking?
My guess, try 5000 Hz, but I have no Idea about the voltage.  How much is required to start the reaction in the air cleaning device?
If you look at that thread I posted, It has some info on high voltage use and static electricity that may be useful to you
We can leave no stone unturned,
Bruce
Hi Bruce,
I have no idea what the frequency would need to be to best create the effect. I almost wish I had one of those air filters to play with so I could see what frequency they pulse the plates at.
Yes I remember seeing something about high voltage in your thread. I was particularly interested in your passing reference to cold cathode tubes. That was one thing that really got me thinking about the cascade effect.
God Bless,
Jason O
Bruce_TPU
Jason,
"Any home ionizer has the potential to produce RF burns even through protective gloves. Electrical Gloves are recommended but not totally full proof over longer periods. The ions tend to ride a few centimeters above (traveling along) the wires and then spread outwards. Over time saturation of the negative ions will build-up slowing or stopping the pulse propulsion i.e. electron flow. Too few holes on the positive ground side of the plate i.e. too few positive ions results in no working propulsion system."
http://www.padrak.com/ine/NEN_4_6_5.html
Could this be further proof....I think SO, NOW I am really excited about this theory
Remember the RF fire from the TPU!!
Also in the above link something else was noted in his experiment, "AN INCREASE of weight on a object attracting the Ions.  Think "increased density"  think "UFT-Unified Field Theory"
I found this  on a patent for an Ionesphere machine that cleans air..
"wherein said series of alternating polarity voltage pulses are of substantially equal voltage magnitude;
wherein the time duration of positive pulses from said alternating polarity voltage pulses are substantially equal to the time duration of negative pulses from said alternating polarity voltage pulses; and
wherein said series of alternating polarity voltage pulses have a frequency of from about 0.05 Hertz to about 4 Hertz;  (Could we be right back to the whistler wave of around 8 Hz, but with High voltage?)
whereby waves of ions of opposite polarity are created which assists in moving said air ions away from said ionization means."
http://www.freepatentsonline.com/4829398.html
And:
"The Bench Top Ionizer employs a safe non-nuclear AC
ionization source. AC systems utilize emitters that are
switched rapidly between positive and negative high
voltage, usually at the power line frequency (50/60 Hz)."
http://www.desco.com/pdf/tb-2016.pdf
And:
"The circuit of the high-voltage air ionizer consists of 3 parts
   1. RC oscillator and power driver
   2. high-voltage cascade multiplier
   3. ion generator
I'm going to describe each of the parts in more detail now."
circuit schematic high voltage ionizer for some ideas at:
http://www.geocities.com/~uwezi/electronics/projects/ionizer.html
Could this idea be a referance to SM's "Phenomona of magnetic collection"  Turning Ions to current?  Static electricity IS high voltage no current.  So perhaps the pressure waves, magnetic fields, etc, allow the collection of these Ions= Power.
Hmm...Just thinking aloud again.  Ions can be produced using High voltage VLF (very low frequency)  This would combine Otto's work and gk's.  Otto is having some success with AC VLF whistler wave.  But If not mistaken, at low voltage.  If that voltage were bumped up....
Jason,  This could be the last missing element.
Bruce
