Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 57 Guests are viewing this topic.
giantkiller
Quote from: aether22 on January 16, 2007, 12:37:33 AM
--giantkiller. You gonna post a picture of your monster before the towns people torch it?
Talk at ya tomorrow.
It's Camera shy, sensitive about it's hair. (I just have the wires going everywhere)
I'll post it soon, but please don't point and laugh.
I totally agree with you. A bad wire day is nothing to thrust in the condeming public eye. But don't worry I will go first...
Here is the runaway firewall circuit in circuit, and a test with 8 gauge audio cable (GK5). Although this later test is not fully tested yet.
Also,
I am not here to condem, judge or snipe at any attempts. If this project couldn't be done we wouldn't be here.
--giantkiller. The greatest accomplishment came from the attempts condemed by the largest groups. Can you say aeroplane made from bicycle parts?
FatBird
I greatly applaud GK's success.  But I think the main reason WE as a group haven't achieved success is because we have lost our focus.  If we re-read the 13 PAGE ATTACHED FILE (MS Word format) containing SM's words & admonitions ( and watch his videos), he mentions 3 Control Windings over the Collector Winding to cause a Rotating Magnetic Field.  Remember that he uses the analogy of  a GRADUAL "revving up" (or down) like a turbine.  He says we can SEE IT on a compass placed in the center.  Remember, SM said that modern MICRO CONTROLLERS make things easier.  Hmmmmmmmm, why did he mention Programmable Micro Controllers?  Let's see.
So far, most of us have been focusing on 3 different Frequencies,  BUT, how can 3 frequencies, feeding 3 Control Windings, NOT SYNCHED TOGETHER, cause a Rotating Field.  The answer is they CANNOT.  How can they?  When Freq 1 is rising on the scope, Freq 2 might be falling, & Freq 3 might be at zero.  This is feeding continuously conflicting data to the Coils.  No, this will not do it my friends.  Unless we can rotate the field in synchronization (to Rev it Up), we cannot achieve success.
Plus, why build 3 Levels all at once.  Why not build 1 Collector Coil Level with the 3 Control Windings on it to test our circuit with a compass.  One level, rather than 3 will at least tell us if we are on the right track.  Levels 2 & 3 can be added later after success with Level 1.
The objective is to Fire a Pulse to Coil 1, followed by a Pulse to Coil 2, followed by Pulsing Coil 3, etc, etc, etc, around & around in sync.  How can this be best accomplished?  I know there are many ways, such as Crystal Controlled Oscillators, Phase locked Loop Circuits, & Micro Controllers.  But I can immediately think of 2 ways that would be the easiest using 555 Timers.  There are hundreds of schematics on the web for Oscillators, 1 Shots, & Delay Circuits that use 555 Timers.
METHOD 1:    How about a Circuit that has four 555 Timers fed from at least 12 Volts.  Timer 1 would be the Main Variable Oscillator to adjust the Main Freq.  This Timer could feed 3 other 555 Timers configured as One Shots simultaneously in synchronization.  The three 555 One Shot Delay Pulse Widths would be configured to output 3 different Pulse Widths IN SYNC!!!  This configuration must cause each Coil to be Pulsed SEQUENTIALLY, 1,2,3, around & around & around, in a circle!!!
METHOD 2:   Method two is using a Shift Register.  One 555 Variable Square Wave Oscillator would feed a Shift Register that would sequentially fire Power Transistors that Fire the 3 Coils.
Respectfully Submitted.
Thaelin
I can agree with this, in the texts of the old messages;  3 coils for sure. It also does state in there using 1 frequency and the second and third being harmonics of the first. Just dont know which ones. Also states turn on freq1 and wait a bit, then freq2 and wait a bit, then freq3. When they start to sync, that would sure make a revolving mag field. Just some musing along that line.
sugra
mkt3920
From the past messages I see reference to three coils for the COLLECTOR coil but no number on the control coils.  Where are you getting this info?  The pictures of the open unit visually show 4 control coils, (two sets opposing each other?).
quote:
About the collector:
It is three separate coils of multi strand copper wire laid one on top of the other, not interleaved. Three is important. You can do many things with three coils. You can run them in parallel, you can run two in series and one in parallel, or etc.
unquote
Kent
giantkiller
Yep! I thank you, Fatbird. That is the 2nd time you've come in after my posts to reiterate very valid findings. Affirmation leads others to progress.
My kicks were said to be obvious but were in line with what Otto had done. But we're the only ones producing them. You speak of synchronization of the 555s. That I don't have yet. I am in the process of implementing that in my existing circuitry. And that is what I want to stress! Somebody mentions an update and I don't need to switch paths, I can just do it. The flexibility to jump is inherent. So I now have time and the platform to pursue that.
And the big thing is, after months of posters postulating kicks, Otto & I got them. But the bigger issue is "We be sloppy!". So that does point to there are many ways to get there. Did anybody else here get immediate mails and postings about the dangers! I think not! What does that show you?
I sit back now and watch for postings of valid input. These posts are a whole different arena of execution now. Remember the look on Jodie Foster's face in 'Contact' when she looked out into the void and exclaimed 'It's beautiful!'? I been there for 2 weeks! I am still amazed and exhausted. Wish you all could join me.
I didn't answer electical questions because I don't care! That is somebody elses job. I don't care what color the tires are. I am flying down the highway.
So. Thanks to all for everything that has been posted. There has been an infinite amount of knowledge here. The TPU really does work, up to this point. It doesn't matter if it can be explained away. I don't give a damn! I've seen enough talk Since Sept 2006.
I got fun under my sun! And most important. If this TPU isn't it, who cares! I got past the diatribe to experimentation. Shit, that was easy. Now I can dream further.
@Fatbird, tnx for the doc. I am playing catch up. And I have a feeling I'll be the one to make the next step...
--giantkiller. I am not going anywhere. Everything has value and it's all good!
