Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Magnetic collection, big time.
Between Dan & I over Fritos and and a kitkat we casually, using our massively oversized intellects, came across this known facet of the universe.
'We are electrically biasing the top and bottom coils. The center coil is what collects the spinning field which = magnetic collection.'
TaDa!
--giantkiller. Skip dinner. You got work to do.
devilzangel
Quote from: giantkiller on May 21, 2007, 06:27:42 PM
TaDa!
Tom Valone talks about this in his lectures
devilzangel
Bruce_TPU
MY, my, my!  That could be SM's "circuit potential", short wires and frequencies.
We eagerly await.
Great job, gk! ( ;) If it works! LOL)
Bruce
Jdo300
Hello Everyone,
Given Giantkiller and Dan's brainstorm, I thought I'd drop a few tid-bits into the mix. Below I have attached a couple of papers that I wrote a while back about the TPU. They deal with the exact effect(s) that GK mentioned in his post. I still believe that these effects apply to some extent though my present theory has vastly expanded since I wrote the papers. Enjoy!
God Bless,
Jason O
giantkiller
I see the Poynting field outcome(previous post) connected to the LMD/TEM tranmisson techniques.
I performed the LMD/TEM type experiment using the GKMTC-ezflow.
In reference to the attached pic
Schematic A adds 1.5 vols D.C. to the output. Standard filter cap operation.
Schematic B is very interesting. The original signal is in all windings. But I get something else.
....III....III....III....III. At resonance, about 85khz, I get a higher voltage (III), about 5v, pulsing in the 2.5 volt square wave(...).
The caps are 250v, 470uf.
--giantkiller. I travel on.
