Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
turbo
yeah, but why is it in Steven's video?
Bruce_TPU
Perhaps it was used to illustrate some of the principles going on in the collectors to the investors....  ;)
I remember SM saying to think of the electrons in the collectors as "water" in a hose.
Grumpy
Good analogy.  Yeah, bet that's it.  Give the peeps the squeeze - pun intended.
        -Frank Edwards
innovation_station
@turbo
looks like a tesla style turbine  humm might the turbine be in the vid for this reason to tell us what way the tpu spinns? the dirrection if you know what i mean
about turbines i just ran mine for the first time and what can i say WOW!!!!
making vids tonight putting them on youtube and overunity
my turbine will spinn the fastest on earth  ;D ;D ;D
i garentee it right now im guessing it spinns at around 10 000 rpm it weighs 30 lbs and is running on 1500 psi  just thought i would share it im soooo happy!!!!
the world is changeing too fast now hehehe but we need it
isteam!!
about the tpu i wound 3 more today diffrent collector configs i now have 7 rings and im building more as we speek all of them are the same style  the turbo gk style
Dansway
Can someone repost the the high resolution pics of the open tpu unit?
~Dan
