Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 50 Guests are viewing this topic.
giantkiller
1st test:
frequency: 80khz dc hhcoil resonance.
drive: 12v thru 2-10ohm 5 watt resistors
configuration: Only pulse top and bottom hhcoils in parallel, cw
The conductive edge of the plates exhibits the same signal on the loose windings around the hhcoils. The loose windings are at a 45 degree. That means that both the whole plates were banging.
I am done till next conference. I just had a skin fairy on my thumb at a 4" distance. It came over my scope probe. Not enough adequate equipment or info for this type of test. I will leave the 20 ohms in series. This seemed like a borderline effect result. I experienced the same anomalies in testing other coils. Inadequate equipment means noticing strange things with your body.
--giantkiller.
Jdo300
Nice Coil Joe,
Will be interested to see how it works out :)
@Everyone,
Check out this passage from this website I found:
"Heres an experiment I did some time back, redone it recently,,so thought I would update this part. I had a tone generator program on my computer. So I could make square waves,triangular waves and so on at a chosen hz. The frequency was in square waves around maybe 407. something. I tried to run a motor by connecting it directly to the sound card output,,thats where a speaker usually gets pluged to hear sound from your computer. But this would not run the motor. So I took my meter and measured the power output of my sound card with the tone generator going,,on a frequency i already knew would run the motor. My meter read on dcv setting of 20,, 0.85 volts. Then I did the amp test, meter set on dca setting of 20M and it read 1.16 and was still dropping,,so the amperage was not holding even there. So Here is what I did next. I took a transformer, the kind that have a primairy and a secondairy. I connected the output from the sound card to primairy and the secondairy to a rectifier and then to the motor. Note I was not using any type of amplifier here, just straight from the sound card speaker output to the transformer,,then the secondairy of the transformer to a rectifier,,the four prong kind, it uses two for the ac input and gives you two outputs rectified as plus and minus. And to keep it short after some experimentation I found the frequency that worked best,,and the cd motor was spinning very fast,,and thats it for the updated version. I removed alot of the old stuff to this article."
http://www.geocities.com/altenergy2007/index2.html
Additional evidence for the concept in my previous post.
God Bless,
Jason O
Earl
Hi Jason,
You posted your PDF about the Cliff Hazelton FE device.
From page 3of 5:
>>"Now that we have enough information, we can calculate the magnitude of the B field inside the toroid when 10,000V is applied to the coil."
Would it be possible for you to edit this doc and add an image as to how the 10kV is applied to the toroid coil?
from page 4 of 5
>>"So by using the magnetic field inside the toroid to induce an electric field on the plates"
Since the magnetic field is completly confined with-in the toroid, how can it affect any plates?
An image is worth a thousand words.
Regards, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Earl
Hi everyone,
anyone have any ideas what this roud object might be?
Regards, Earl
