Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 18 Guests are viewing this topic.
Motorcoach1
OK  this is a work in progress . EXPLOSIONS  your at risk OK so don't proceed , if you have nothing to give just listen  and yes this will hurt you making the TPU in the neighborhood of 151 kz and 156 thats microwave (critical) the scaler waves that may alter your genies and chromatic metal structure you may be at risk but if you need carry on , you never know enhought  ( this is a warning this project may not be safe  to your health .) OK you have another warring ....!!!!!!! we post this everyone as we go forward .........test safely
bob.rennips
Quote from: kames on May 28, 2007, 08:08:55 PM
@All
A few pages back (page 168) I have posted a simple and stupid experiment. Doesn?t look like anybody picked it up but sorry. Anyone can reproduce it with ease. There was a purpose to post it as a prelude to something else. I was thinking about opening a separate thread but as long as most of the people are in this thread I decided to post it here. It can be moved to a separate thread at any moment. There were several events that struck me when I performed that experiment. First, nobody could give a reasonable explanation. Second, I have found two patents in my unsorted files. Those two patents were backed up just in case a long time ago, before I even started looking for SM?s tpu. When I first time read those patents I decided ?old news?. When I recently read them again having all the stuff of the tpu in mind there were a lot of things to look over again. There were a lot of things to try to understand what SM was trying to tell from his every single message through Mannix.
I am in the process of testing those two patents. That is not a manual to how to do the things. Those are basic ideas and results.
The first patent (file name) I changed to ?power unit?. The second (file name) I changed to ?control unit?.
In the power unit the text is much more important than the drawings. Read it all. Don?t miss a single line. Drawings are not the same as what text is saying.
In the control unit, the drawing might remind you what you saw in the videos. It is just a nice technical solution.
I have scanned all the attachments from this forum and didn?t find anybody ever posted it before. Maybe I missed something. In this case, just disregard this post.
If you read these patents for the first time, come back and see what I posted on page 168. Any criticism or opinion is okay except for teaching me how to use a scope or probes or asking if I forgot to check my battery charge.
Again, I haven?t tested everything from these two patents. I am in the process. If anybody can get ahead, it is only better.
Regards,
Kames.
Celestial Energy Corporation - pretty near in meaning to Universal Energy Corporation, I would say. This is exactly the sort of clue SM likes to give - obvious what he was getting at but only after you know what he is referring to!
The essence of the patent is. You need to peturb/twang an existing static magnetic field with a particular sequence of pulses. In return you get back magnetic oscillations of several 1000 times greater that the input.
Note in the patent the diagram showing the pulse heights IS NOT TO SCALE!. When you replot to scale figure 2 c) the waveform looks more like a sinewave with a low frequency modulation on the top... (7.8hz?)
However SM has said use frequency plus 1st and 2nd harmonic.
So obvious experiment using basic air core solenoid shape.
1. 1st coil with say 2 layers connected to 50v DC. This sets up the static magnetic field.
2. 2nd coil is a trifilar coil wrapped as one layer. Connect the 3 pair to 3 sources of frequency with relationship as above. What voltage amplitude to use ? Patent suggest these need to be in the 100s of volts but worth trying more obtainable amplitude of 12-24volts first.
3. 3rd coil of heavy gauge wire of say 3 layers is your output.
I've had unexplained burnouts of stepper motor circuits when using a DC solenoid around rotating magnetic fields (that were rotated  by the stepper motor circuit).
This a great find Kame. Thanks for sharing.
Rosphere
Jason,
You may be on to something with your capacitor-plate, E-field line of reasoning. Perhaps this is why the two open units do not work when inverted.  The larger units that are glued to a base-board may not work inverted either.  The units he does invert successfully may actually be two units, back-to-back, with one always upright--both sharing the same middle cap-ring, which is why there are three cap-rings.  (I wonder if these units have a small "blind spot" when they are held vertically.)
Perhaps all we need to do is figure out how to make coils interact in such a way as to magnify the naturally occurring charge difference in separated cap-ring-plates and then tap this much larger free charge?
I think I will spend some time searching and learning about Earth's E-field.  How strong is it?  Does it resonate?  At what frequencies?
Thank you,
Rosphere
Rosphere
There is another line of reasoning about resonant chambers.  My microwave still works inverted.
Jdo300
@All
Regards,
Kames.
Hi Kames,
I must commend you on that great find of a patent! All of the different frequency mixing methods we have discussed fit in with it (beat frequencies, mixing, phase shifting, harmonics etc...).
I wanted to let you know that I will be duplicating your original kick experiment. In light of seeing this patent, I now know why you used the permanent magnet. I got a little confused by your description of how the wire behaved though when you were explaining what it did when you held it in different spots. Perhaps you could do a video of the experiment to show everyone the behavior of the wire? I would make one myself but my camera is temporarily missing   :-[.
@Rosphere,
That may be the key there, but then again, the magnetic implosion effect may be all that we need to bring in the energy. Remember the nuclear explosion that created the great EMP collapse afterwards.
Anywho, if you would like some info on the earth's ionosphere, here is a good start:
http://en.wikipedia.org/wiki/Atmospheric_electricity
http://en.wikipedia.org/wiki/Earth-ionosphere_cavity_resonance
Note that the Schumann cavity resonance is stimulated by lightning strikes! Lightning strikes are essentually big 'kicks' that occur roughly 100 times a second all over the globe. So if you tune your TPU to some harmonic of the schumann resonant frequency (which by the way is a pulse wave), these pulses can help add more kicks to your TPU...
Other info you might find useful:
"What is a Schumann Resonance? Believe it or not, the Earth behaves like an enormous electric circuit. The atmosphere is actually a weak conductor and if there were no sources of charge, it's existing electric charge would diffuse away in about 10 minutes. There is a 'cavity' defined by the surface of the Earth and the inner edge of the ionosphere 55 kilometers up. At any moment, the total charge residing in this cavity is 500,000 Coulombs. There is a vertical current flow between the ground and the ionosphere of 1 - 3 x 10^-12 Amperes per square meter. The resistance of the atmosphere is 200 Ohms. The voltage potential is 200,000 Volts."
Taken from: http://www.healeroliver.com/Schuman_Resonance.html
Hmmm... Vertical current flow?? Hmmm.... now that has me thinking... If there is a vertical current flow between the ground and the sky all the time and we make a TPU device which suddenly creates a huge potential drop in the surrounding space between it and this "sky current" what do you think will happen to the rate of the current flow from the sky to the ground?
God Bless,
Jason O
