Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 31 Guests are viewing this topic.
Rosphere
Quote from: Jdo300 on May 29, 2007, 09:48:44 AM
Hmmm... Vertical current flow?? Hmmm.... now that has me thinking... If there is a vertical current flow between the ground and the sky all the time and we make a TPU device which suddenly creates a huge potential drop in the surrounding space between it and this "sky current" what do you think will happen to the rate of the current flow from the sky to the ground?
Well, in the two-plate, inversion sensitive, designs: if we positively charge the lower plate, would this increased sky current negatively charge the upper plate?
And how would we go about putting a massive positive charge on the lower-plate-ring-ignition-coil-core?
nong
@GK
I test GKMTC1, put pulse 1khz- 3%duty cycle to 2hhcoils.
Input 5 volt to 1 end of hhcoil.
Pulse another 3 controllers.
I got this pic at end of other hhcoil.
I got feedback to mosfet gate too   ???     Is that OK?
Thank you.
nong
Jdo300
Quote from: Rosphere on May 29, 2007, 10:17:30 AM
Very simple. When we pulse the collector coils with very sharp high voltage pulses, the whole coil charges up to a single polarity. I have experimentally seen this just by putting my scope probe across a resistor attached to the collector on one of my TPUs. No matter which way I stick the probe/ground combo across the resistor, the spikes I got would always show up as the same polarity on the scope screen! Normally when you reverse the probe and ground connection, the polarity flips over. My thought is that the first case can only happen if the coil is the same potential everywhere compared to ground.
So if we make some really high voltage kicks and 'pump' up the potential of the collecotor coil (through resonance), then it could charge up to a high enough potential to look like one side of a capacitor plate to the earth's ionosphere. Or at the very least, a drop in potential compared to the surrounding space. And just like a funnel, the surrounding energy will go where the greatist potential drop is.
I can't answer your question about the interaction with the sky currents but I sort of visualize it like putting a vacuum turbine into the bottom of a big tank of molasses. The molassas would be like the resistance of the air. When you fire up the Turbine (TPU), it starts to rotate and also suck in molasses from the area. As the turbine rotates the molassas, a funnel would form and create a swirling sinkhole where something from the surface could get sucked down into the turbine faster, like a whirlpool.
Another example would be this. If you have a sink with a garbage disposal in it, fill it full of water and then open the drain and turn it on. If you give the water some swirl to start, it immediately tightens up into a big vortex and a big 'hole' forms in the water from the surface all the way to the drain hole. So inside that funnel, I could easily drop something into the drain without the water 'resistance' to stop it from falling. In the same way, the TPU may be electrically doing something like this to the atmosphere when it is in operation; creating a lower resistance between it and the top of the atmosphere so that the current can flow straight to it. This may also explain why it stops working if you flip it over :).
God Bless,
Jason O
giantkiller
Quote from: nong on May 29, 2007, 10:43:46 AM
@GK
Thank you.
nong
@nong,
Yes. The feedback a the gate is good. It is a start to self resonance.
Gentlemen! We have another winner!
From simple beginnings come great things. The GKMTC1 does this. I exacerbated the results by putting an aluminium ring on top and bottom (Thx Dansway). I do not recommend this! It produces skin fairies. That means you feel the lower part of the distributed energy. Guess what happens with the upper side frequencies?
@Rosphere,
I found that when I turned the microwave oven upside down i got anomilous results. The food was a mess but it still tasted the same. I just ate it differently. Lol.
@all,
So i looks like we have handheld sonic boomers here. Sine we don't push physical matter in space we don't get the audio feedback. By pushing magnetic fields to their limits we get mag boomers instead. Hmmm... Doesn't this sound like micro-waves? Please back away from the coil!
@Jason,
According to the step circuit, 1 on, wait, then 2 on, wait, then 3 on wait, then all off! We get a huge collapse going down the vacuum drain. We softly build the field. So when the accumulated field collapses the spin will happen because it is simply more powerful.
Play with the fields: http://web.mit.edu/8.02t/www/802TEAL3D/visualizations/magnetostatics/teachspinapp/teachspinapp.htm and watch these babies rock!
Yes, Motorcoach1. We must exercise caution. Be careful.
Thanks Kames! Great posts. Another great turn. Pun intended.
--giantkiller. Attention, Race fans!
giantkiller
Oh my God,
In re reading the power unit patent at the signal generation section, patent page 7, section 20 and on. Follow on here:
The GK4 has the embodiment and all the deviations the author mentions. The iron core reproduces the center magnetic core electrically, the 100 winds or so to produce the deviated pulses sequences, connecting the 2 pulse lines together producing phase cancellation, in synch and randomally. Damn! This is so reproducable it pathetic! By simply altering the pulses I could jump anywhere into the signal description of the patent and get results! Of which I have already seen!
I didn't see it before. The GK4 is a totally open model for the deviations mentioned in the patent. No wonder this thing is so dangerous! You all should not have to get so complex.  This is why c0msters magnetic resistor worked back in December 2006!
I achieved dangerous, flesh crippling output from 30awg coils which remained in intact.
I think I am done since January 03, 2007! I am just going to swap around some connections slightly and see what happens. The GK4 is a little different because of the 3 layers is all, and four coils per layer. I got the Beast of all coils! I just have to do more configurations. The external stereo cable / feedback winding is partial containment.
@Nong,
Match up your coil and applied signals to the patent power_unit.
@Motorcoach1,
You do the same.
--giantkiller.
