Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
bob.rennips
Quote from: starcruiser on May 29, 2007, 04:57:32 PM
tubes can handle those voltages more readily than semiconductors, speed is also a factor. Maybe even the flux fields affect on the semiconductors.
Now what if the core is just a bundle of copper wire and the neo magnet supplies the magnetic field? This allows us to start and stop it, no?
Look at the pix of the open frame unit, thoise are stacks of ceramic magnets right? The cylindrical object might be a starter or even a DC motor that provides the smaller pulses (brushes creating the spikes), the larger spikes from a voltage multiplier? According to the patent the power is obtained froim the enhanced mag field and the spikes voltage differential.
The feedback coil is then the output coil perhaps. On the open frame unit the output is more than likely the 18ga speaker wire (that is a guess on the wire size).
Thoughts?
Correct me if I am wrong here , but isn't 10^-12 about 1 terahertz?
I think the patent was making the point that 10^-12 was the minimum period i.e. this is the smallest period that works. No mention is made of the larger period between multiple pulses. In fact elsewhere the patent specifically mentions that it can work with a single pulse sequence on one wire. I believe the reason for putting this minimum in, is so that no one can get around the patent by claiming that they are using much smaller pulses periods. Perhaps other gravitational anomalies start appearing at much smaller pulse periods ?
My take on what is happening is. A magnetic field appears in space around a coil at the speed of electromagnetic transmission. If you have a static electromagnetic field you already have a field established in the ether. If you then put a high voltage pulse down a coil, another magnetic field appears at the speed of electromagnetic transmission. This rapidly expanding field ,if you like, 'hits' the static field causing it start distorting. i.e. it gains momentum in the direction of the distortion. When the pulse finishes, the causing magnetic field collapses, but the static field having some momentum continues to distort. As soon as that momentum is used up, it is going to rebound back. The trick is to have another much larger magnetic pulse already expanding as the previous pulse is collapsing. you now have two fields coming together at twice the speed of electromagnetic transmission. The resulting ripples in the ether from this collision manifest as a large magnetic field.
So the period from one series of pulses to the next serios of pulses is not as important as the time between the low and the high pulses in the series. In fact I'd hazard a guess that the reason for using a high voltage of 380volts for the first pulse is so that the momentum of the first distortion is large enough to give enough time to get the second higher voltage pulse out to hit it on it's return.
Imagine a tennis player, if he doesn't throw the ball up high, the ball returns back down in a short period of time, giving him less time to hit the ball with the racket. Give it a good throw up in the air, you have a longer time before it returns and can successfully have the racket (second pulse) already moving ready to hit the ball.
bob.rennips
Quote from: giantkiller on May 30, 2007, 12:17:00 AM
...The iron wire was a configurable iron core wrapped in 200 turn 30awg. Just like mentioned in Celeste Energia patent. So I have 12 of these coils monofilar configured into 12 opposing Tesla coils at any given time. I think Niky would like that...
I think we need to be careful not to confuse people.
To avoid confusion there are two patents. The first is a unit that generates the pulses with the correct timing. There are many ways of doing this with standard electronics. They choose to use a transformer with an iron core. There is nothing particularly exciting about this patent - other that the fact it is very robust to excess volt.
The second patent makes it clear that you need a static magnetic field that is either generated from static magnets or from an electromagnet. The patent also makes it clear that the magnetic field generated from the pulses has to align with this magnetic field. It is also clear that the coils do not have an iron core.
i.e. If you wrap an air core solenoid to generate the static magnetic field, the pulsing coils need to be wrapped on top in the same direction and the same sense.
SM does not appear to be doing this at first glance. But I believe SM is doing something similar by having a circular standing wave. This is in effect the equivalent of the first pulse. The second pulse is sent out from the control coils.
eldarion
Quote from: bob.rennips on May 29, 2007, 04:44:08 AM
I've had unexplained burnouts of stepper motor circuits when using a DC solenoid around rotating magnetic fields (that were rotated  by the stepper motor circuit).
What you just described is Steven Marinov's MAGVID!
Coincidence?  I think not! :D
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
bob.rennips
Quote from: eldarion on May 30, 2007, 02:03:17 AM
Exactly. It was marinov's MAGVID stuff, a couple of months ago, that got me thinking about having a DC field. I also posted a relevant tesla patent that showed how he used coils to act as a rectifier. Having determined that coils could produce rectified DC I acould see a reasonable avenue to their being DC in SMs devices. The problem is harnessing the anomalies. The voltage appears and burns things out.
It's clear the key is the static field for a simpler proof of concept. However, if you want to get things to a point where the output supplies the input then you need the more complex arrangements of coils of the SM TPU.
