Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
@bob.rennips,
Sorry if I wasn't clear. I was looking along the lines of instead of wrapping magnets in the first patent and that the iron wire / bailing wire idea would fit as a magnetic center. Thus controllable electrically, if need be, that's all. I did see any down side to this use at all. On the upside it could be safer the way it is jumped because the field fluctuated. That is why I mentioned I could just apply dc to the collectors. Very similar to the Helmholtz operation Dansway & I were discussing and that also showed up on Marco's latest coil which IS, Jdo300, and I have reproduced. There has been nothing done in vain and all builds and experiments have value.
There is still magnetic coupling going on and also magnetic field aggitation like the field shearing in the Muller, Bedini, Perendev builds and most of the others we have seen. At this view, alot of experiments are closely related or similar. This approach also gives freedom and justification to remove the mechanical operation in the some of those experiments. SM, Hubbarb, Celeste Energia have done just this. As we all know the mechanical solutions are limited in the future. After this stage of development is completed the much, much higher frequencies can be tried. This is where the real fruit of our labors will pay off. The stage we are trying to achieve now does power conversion.
--giantkiller. RFC
starcruiser
Quote from: bob.rennips on May 30, 2007, 01:17:47 AM
Quote from: starcruiser on May 29, 2007, 04:57:32 PM
tubes can handle those voltages more readily than semiconductors, speed is also a factor. Maybe even the flux fields affect on the semiconductors.
Now what if the core is just a bundle of copper wire and the neo magnet supplies the magnetic field? This allows us to start and stop it, no?
Look at the pix of the open frame unit, thoise are stacks of ceramic magnets right? The cylindrical object might be a starter or even a DC motor that provides the smaller pulses (brushes creating the spikes), the larger spikes from a voltage multiplier? According to the patent the power is obtained froim the enhanced mag field and the spikes voltage differential.
The feedback coil is then the output coil perhaps. On the open frame unit the output is more than likely the 18ga speaker wire (that is a guess on the wire size).
Thoughts?
Correct me if I am wrong here , but isn't 10^-12 about 1 terahertz?
I think the patent was making the point that 10^-12 was the minimum period i.e. this is the smallest period that works. No mention is made of the larger period between multiple pulses. In fact elsewhere the patent specifically mentions that it can work with a single pulse sequence on one wire. I believe the reason for putting this minimum in, is so that no one can get around the patent by claiming that they are using much smaller pulses periods. Perhaps other gravitational anomalies start appearing at much smaller pulse periods ?
My take on what is happening is. A magnetic field appears in space around a coil at the speed of electromagnetic transmission. If you have a static electromagnetic field you already have a field established in the ether. If you then put a high voltage pulse down a coil, another magnetic field appears at the speed of electromagnetic transmission. This rapidly expanding field ,if you like, 'hits' the static field causing it start distorting. i.e. it gains momentum in the direction of the distortion. When the pulse finishes, the causing magnetic field collapses, but the static field having some momentum continues to distort. As soon as that momentum is used up, it is going to rebound back. The trick is to have another much larger magnetic pulse already expanding as the previous pulse is collapsing. you now have two fields coming together at twice the speed of electromagnetic transmission. The resulting ripples in the ether from this collision manifest as a large magnetic field.
So the period from one series of pulses to the next serios of pulses is not as important as the time between the low and the high pulses in the series. In fact I'd hazard a guess that the reason for using a high voltage of 380volts for the first pulse is so that the momentum of the first distortion is large enough to give enough time to get the second higher voltage pulse out to hit it on it's return.
Imagine a tennis player, if he doesn't throw the ball up high, the ball returns back down in a short period of time, giving him less time to hit the ball with the racket. Give it a good throw up in the air, you have a longer time before it returns and can successfully have the racket (second pulse) already moving ready to hit the ball.
Bob I agree with your comments. Testing is now mandatory to test the theory. I am going to pull out one of my older TPU's and try a few things, hopefully work will not impinge on my testing (as it has in the past).
Regards,
Carl
bob.rennips
Quote from: starcruiser on May 30, 2007, 12:43:27 PM
I've started up a separate thread for those of us who want to experiment along these lines and report back findings :) or not :( as the case maybe!
The threads entitled "Proof of concept - perturbing a static magnetic field"
Rosphere
I was looking for a simple circuit that would sequentially start pulses, one by one, and then terminate them all at once.  Perhaps I could feed one 555 signal into this and NPN or MOSFET each output to a control coil?
Rosphere
Like so?  (See circuit below.)
