Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
mrl
Consider this:
It takes one nanosecond for an electrical impulse to travel about one foot along a wire.  That's the equivalent to a one gigacycle pulse.  Tesla remarked that the radiant event would happen during this window of no current flow during switch closure.
So, if you have 10 feet of wire your rise and fall time would have to be around 1 100 millionth of a second.  I believe that's 10 nanoseconds.  The best MOSFET can barely do that.  So, you may want to try going to at least 20 feet of wire for your control coils and see what happens (the pulse width needs to be short).  You may start to see a more dramatic effect.
AhuraMazda
Alas, poor Turbo. I miss him too. I knew he was into something.
AM
aether22
I whole heartedly agree that rotating fields from the control coils are likely key based on previous research. (though I'd expect it possible to do it without a rotating field)
I also think that we should take note of the fact that he either tuned his input to match the control coils, or tuned the control coils to match the input, based on the circumference of the control coils.
This seems to suggest that at least one of the control coils is an open coil (at both ends), free to resonate a bit like a Lakhovsky MWO, either that or oscillations take place within the coil treating the coil as if it's an odd dipole, the two ends being 180 degrees apart.
BTW I think i know how you can possibly significantly advance progress with this coil, and it's an odd one.
Power it from a dynamo rectified and smoothed, or a DC motor run backwards (working as a generator), I believe that there is more than electricity coming from these things, there are many examples but for instance look at the Kipper motor gen setup, I can tell you right away that the coil he uses alone won't do much.
http://www.phact.org/e/z/KipperScam_files/6900052Kipper_Tricks.htm
Look at Tesla, he also used high voltage DC generators to power his coils, no one gets the same results as him because no one uses these to power their coils (which aren't even designed correctly of course).
Look at Alexander, even EV Gray used an Alexander motor/generator!
If you don't want to do that then at least use a vacuum tube as Mark said, as that can help get some aether flowing in the circuit.
As for my photo's, I have taken them, but at the moment my PC is running on a (not totally legal ;) Vista OS, so until I boot it into XP (which has the drivers for my camera) the photo's are stuck.
AhuraMazda
aether22,
Yes a dynamo may have a lot to do with it. I always puzzled why Stanley Meyer used a dynamo to run a water fuel cell in his famous demo.
AM
giantkiller
Hi,
One of the ideas I have held on to since I got here was counter rotation. With the right output material you could get xray from Mhz signals. You run 1 freq one way and a 2nd freq opposite direction. The opposing waves clash into each other causing a higher interference pattern. Something that cropped up was the bifilar feed back coil. we'll use ottos config and at the +v tie them together and see what happens at the other end of the 2nd run which is the position of the start of the first run. This gives the interference from the field opposition. Anyway that is one of the ways to hook up. JDO300 also suggested a 4" tpu made totally out of lamp cord. All bifilar. Cheap and fast. That also gives controllers made of magwire size runs. Instead of all those seperate windings. That would explain the fatness of SM4 & SM6 and outputs hooked directly to a 12awg outlet. The wire can handle the amps!  ;)
--giantkiller. 8)
