Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Gentlemen!
I used tubing with large cable ties.
The wheels don't have to roll. This is the flying model!
I am working on the jumperiing next and packing a parachute.
--giantkiller.
hartiberlin
Hi GK,
looks very nice !
Wilmaaaaaa ! Here we come ! ;)
giantkiller
Thanks all.
It was 4 hours labor only. I had all the parts just sitting around. Go figure...
Dinner is now et. I can continue on.
--giantkiller. Geeknacious.
Bruce_TPU
Hey GK!
If that is standard lamp coil in your house...... I would hate to see your lamps!  LOL
;D
Good luck and cheers,
Bruce
weri812
be carefall gk
dont wont you to burn up that butifull coil and hurt your self
looks like it will pull some large amps at high volts
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
