Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Earl
Hi,
further comments.  This idea is based not on different frequencies (in this case pulse repetition rate) or harmonics, but a rapid sequential firing around the ring.  As the pulse width decreases the probability of radiant events increases.  Just slowly sweep one single frequency and watch for radiant events.  When the 1000 Watt light bulb fully lights up and then goes PING, you have found the sweet spot. hehehehe
Enjoy, Earl
"It is through science that we prove, but through intuition that we discover." - H. Poincare
"Most of all, start every day asking yourself what you will do today to make the world a better place to live in."  Mark Snoswell
"As we look ahead, we have an expression in Shell, which we like to use, and that is just as the Stone Age did not end for the lack of rocks, the oil and gas age will not end for the lack oil and gas, but rather technology will move us forward." John Hofmeister, president Shell Oil Company
Earl
Hi,
sorry, keep forgetting things.  See attachments.
Also include a long list of most 74HC ICs from the NXP (Phillips) site with hyperlink to download datasheet.
Enjoy, Earl
giantkiller
Quote from: ronotte on June 13, 2007, 03:13:40 AM
@GK,
...pay attention, the place you put the battery (or P.S.) is wrong...check with the schematic TPU=ECD. (there's not a battery V3, and V1=12V).
Hope this help
Roberto
Thanks. I mistook the V in parallel with the lamp as a voltage source.
Do not worry. I will be safe. Got hurt twice and no more.
--giantkiller.
gn0stik
Earl, nice schematic, but this might be a better unit for driving a tesla coil than a TPU.
Duty cycle needs to be adjustable independently of frequency. We also need the ability to have more than one frequency.
I suppose this would be great for a three ring TPU, where we have multiple controls on different rings being driven at the same frequency. We could have three of these units driving the controls.
PRR is important, and the rise time is fantastic! but pulse width is important too, and therefore needs to be independently adjustable. These RF effects that make it so dangerous to be in the room with may well disappear at different pulse widths.
quote from gerry
Tesla found that impulse duration alone defined the effect of each succinct spectrum. These effects were completely distinctive, endowed with strange additional qualities never purely experienced in Nature. Moreover, Tesla observed distinct color changes in the discharge space when each impulse range had been reached or crossed. Never before seen discharge colorations did not remain a mystery for long. Trains of impulses, each exceeding 0.1 millisecond duration, produced pain and mechanical pressures. In this radiant field, objects visibly vibrated and even moved as the force field drove them along. Thin wires, exposed to sudden bursts of the radiant field, exploded into vapor. Pain and physical movements ceased when impulses of 100 microseconds or less were produced. These latter features suggested weapon systems of frightful potentials.
With impulses of 1.0 microsecond duration, strong physiological heat was sensed. Further decreases in impulse brought spontaneous illuminations capable of filling rooms and vacuum globes with white light. At these impulse frequencies, Tesla was able to stimulate the appearance of effects which are normally admixed among the electromagnetic energies inherent in sunlight. Shorter impulses produced cool room penetrating breezes, with an accompanying uplift in mood and awareness. There were no limits in this progression toward impulses of diminished duration. None of these impulse energies could be duplicated through the use of high frequency harmonic alternations, those which Sir Oliver Lodge popularized, and which later was embodied in Marconi Wave Radio. Few could reproduce these effects because so few understood the absolute necessity of observing those parameters set by Tesla. These facts have been elucidated by Eric Dollard, who also successfully obtained the strange and distinct effects claimed by Tesla.
Now, he worked with MUCH HIGHER initial voltages, and currents on MUCH larger coils than we are working with, so we probably won't see some of the effects (objects moving, etc), because they are likely relative to the energy levels used. But others (pain) we have already seen.
giantkiller
