Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Thanks guys.
I will search Maxim-Dallas for these similar issues. They are a great company with good support. I should find an answer to this.
In the 12 years I haved used Maxim parts I found they have very stable reliability with good internal protection. Of course I have never pushed them like this project does. Should prove interesting.
--giantkiller. Any other input or history is welcome.
giantkiller
Rise and shine, posters!
Here. Take a look at this.
http://blazelabs.com/emwaves.htm
The resultant power we are looking for is exiting at a different vector other than current down a wire.
In other words, you can't look east while not panning with binoculars across a body of water at a boat that is traveling north / south across your view while there is a car coming up behind you at a high rate of speed. You won't see the car and you will only get a glimpse of the boat.
That is why our 'Current in the conductor' instruments don't measure anything. We are only seeing the by-product of energy degradration in our spectral viewing plane. The real energy we want is heading off in another direction / another vector.
Diodes looks like shorts. DVMs act like balls of steel wool. Coil based instruments work but not really all the way there. Scopes are blown up. Skin fairies jumping off devices to the operators. There is your OU right there. Simply put: measuring devices made in the model of 'current in the conductor' don't see anything here. Wrong vector.
And that is also why there has been no true power harvesting. You cannot carry sand in a sieve. We are donning chain maille as floatation devices. But capacitors, stressed inductors due to resonance, small latch magnets in the field all cause a vector realignment of one or all of the vectors.
All the exciting devices we have seen use either High voltage, current or frequency. Here we are again trying get something for nothing by blowing sh!t up! Please. Look at this model of thought when Eintstein said 'How about 50 miles' when Oppenheimer asked about '50 foot' distance from the alamagordo nuke test. I'm starting to see Oppies thought as much better.
And here we go again with another stungun:
http://blazelabs.com/e-exp16.asp. Oooow. Big whoopty doo! Tesla stated the amount of energy is infinite. But we get excited about the light show. The same experiment can be reproduced in 2 ways. Take a laser pointer to the zoo and shine on the objects in the monkey cages. Or throw a cell phone in the chimpanzee cage and wait till the alpha dude picks it up then call it. Please do not attempt this while under the influence of any mind altering drugs. You'll laugh so hard you'll die right there.
And Tesla operated his remote control boat by tapping a telegraph key on a small box. Hmmm.
And go back a page from the above link and look at the EHD.
EHD Thrusters research section contains a series of experimental EHD Thrusters or propulsion devices, also known as ionocrafts and lifters, that do not use conventional methods for thrust. They still obey all Newton's laws of motion but they do not need to carry their thrusting fuel. In general, EHD thursters have an air ioniser in the form of a fine wire, fixed at a small distance (few cm) over the collector, usually in the form of an aluminium plate of foil with smooth round edge at the upper part. The thrusting mechanism is called Electrohydrodynamic (EHD) and is provided by the well known Coulomb's law of electrostatics acting on ion clouds, and by the law of conservation of momentum, by which it transfers momentum of these accelerating clouds to neutral air molecules. As you can read in Lifters in vacuum, lifters are NOT antigravity or electrogravity devices. Unfortunately the general lack of information on their mechanism has resulted in these devices being claimed (and also sold!) as antigravity science kits. These devices are able to lift their own weight and even additional payload. Our aim is to find the best design & materials to construct the most powerful unit EHD cell in the smallest possible space and explain in full how it works. Blaze Labs Autonomous thruster project aims to develop a high power thruster capable of carrying its own power supply & also extra payload. Please note that these devices use very high voltages (>30KV) and experience in handling high voltage is a must. We are not responsible if you get killed!
And:
Tesla's tublike craft powered itself; there were several large batteries on board. Radio signals controlled switches, which energized the boat's propeller, rudder, and scaled-down running lights?simple enough in concept, but quite difficult to accomplish with existing devices. Even registering the arrival of a radio signal pulse taxed the rudimentary technology. Tesla invented a new kind of coherer (a radio-activated switch) for this purpose, essentially a canister with a little metal oxide powder in it. The powder orients itself in the presence of an electromagnetic field, like radio waves, and becomes conductive. If the canister is flipped over, after the pulse's passage, the powder is restored to a random, nonconductive state.
Tesla contrived for a number of things to happen when the coherer conducted, most importantly for a disk bearing several differently organized sets of contacts to advance itself one step. Thus, if the contacts had previously connected the combination "right rudder/propeller forward full/light off," the next step might combine "rudder center/propeller stop/lights on." And with the aid of a few levers, gears, springs, and motors all would be accomplished, including a final step, flipping the coherer over so that it was ready to receive the next instruction.
--giantkiller. Let's rethink, shall we? Or we will never escape the cage...
innovation_station
you all know me and im all about thinking
i think this is much easyer than all of us think i also think we have looked too hard already i hope to focous on the ring as soon as i finish this job im on when i can devote the time and the tools to it
who is working with tubes i still think it will be the easyest way to get something to work and also 3 6 9 what is the deal?
sounds like 3 harmonics of the same freq
is
giantkiller
Intra board coupling stage complete.
Next steps are:
Inter board coupling stage,
Sequential power up and component configuration test,
Fet to TPU connections and test,
Duty cycle and frequency tests.
The ic board has small sockets for all discreets. Nothing is hard coded.
The Fets are even in sockets with the terminal blocks. I can eject them at any time to be placed in the center of the TPU. TaDa. And we will get to the bottom of that noise.
Building junctures and great cities of the future.
--giantkiller.
innovation_station
been rereading some of the links i have and i came across somthing intresting in a tesla patend for his pancake coil here is a clip from the pattend
have found that in every coil there exists a certain relation between its self-induction and capacity that permits, a current of given frequency and potential to pass through it with no other opposition than that of ohmic resistance, or, in other words, as though it possessed no self-induction. This is due to the mutual relations existing between the special character of the current and the self-induction and capacity of the coil, the latter quantity being just capable of neutralizing the self-induction for that frequency. It is well known that the higher the frequency or potential difference of the current the smaller the capacity required to counteract the self-induction; hence, in any coil, however small the capacity, it may be sufficient for the purpose stated if the proper conditions in other respects be secured in the ordinary coils the difference of potential between adjacent turns or spirals is very small, so that while they are in a sense condensers, they possess but very small capacity and the relations between the two quantities, self-induction and capacity, are not such as under any ordinary conditions satisfy the requirements herein contemplated, because the capacity relatively to the self-induction is very small
here is the link for the rest of it http://www.tfcbooks.com/patents/coil.htm
also i found somthing else about a saw osolator im sure it will b of intrest here is the link and a clip from that pattend http://www.patentstorm.us/patents/6653906-claims.html
a SAW oscillator circuit for generating a controlled-frequency output signal and having a voltage-variable control input for adjusting a frequency of the controlled-frequency output signal, the oscillator circuit including a voltage variable capacitive element responsive to the control input, a surface acoustic wave (SAW) resonator operably linked to the voltage variable capacitive element, and a gain stage for energizing the SAW resonator
well it is a little over my head right now but thought i would post it but it kinda fits also there is a steven and a mark that is how i found it
hope this help someone
is
