Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
Quote from: innovation_station on June 17, 2007, 08:19:53 PM
been rereading some of the links i have and i came across somthing intresting in a tesla patend for his pancake coil here is a clip from the pattend
have found that in every coil there exists a certain relation between its self-induction and capacity that permits, a current of given frequency and potential to pass through it with no other opposition than that of ohmic resistance, or, in other words, as though it possessed no self-induction. This is due to the mutual relations existing between the special character of the current and the self-induction and capacity of the coil, the latter quantity being just capable of neutralizing the self-induction for that frequency. It is well known that the higher the frequency or potential difference of the current the smaller the capacity required to counteract the self-induction; hence, in any coil, however small the capacity, it may be sufficient for the purpose stated if the proper conditions in other respects be secured in the ordinary coils the difference of potential between adjacent turns or spirals is very small, so that while they are in a sense condensers, they possess but very small capacity and the relations between the two quantities, self-induction and capacity, are not such as under any ordinary conditions satisfy the requirements herein contemplated, because the capacity relatively to the self-induction is very small
here is the link for the rest of it http://www.tfcbooks.com/patents/coil.htm
also i found somthing else about a saw osolator im sure it will b of intrest here is the link and a clip from that pattend http://www.patentstorm.us/patents/6653906-claims.html
a SAW oscillator circuit for generating a controlled-frequency output signal and having a voltage-variable control input for adjusting a frequency of the controlled-frequency output signal, the oscillator circuit including a voltage variable capacitive element responsive to the control input, a surface acoustic wave (SAW) resonator operably linked to the voltage variable capacitive element, and a gain stage for energizing the SAW resonator
well it is a little over my head right now but thought i would post it but it kinda fits also there is a steven and a mark that is how i found it
hope this help someone
is
Sounds pretty obvious there bud as part of the feedback control. This is what I was going to do. Kinda like a phase-locked loop. Fits right into any pre-existing 555 astable circuit.
I checked out my fet board. The fan runs. Put discreet components and 556s in the sockets on clock board and that runs fine. I will put the Max621 driver chip in next to test the 556s as inputs. Used my new scope. It works like a charm. It has alot of features built into it through the software interface.
--giantkiller. Till next session, be at peace.
joe dirt
also another interesting read... and I,m interested in how these type of speakers
  would do in a helmholtz/toroid fashion instead of linear.
joe dirt
I remember Tom Beardon saying once,  well, I can,t remember the exact quote but
  it is something like this, "the simplest device is a capacitor and a horseshoe magnet,
  place the cap in the field and it,s-- something," I can,t remember the rest but the
  gist of it is not to destroy the dipole, but being able to couple it with a tuned circuit
  Etc..
I thought about doing an experiment, take a tuning fork, put it in a fixed position and
  isolate it (electrically), wind a coil around it, large enough to where it,s not
  touching the fork, then apply a negative potential to the fork via static or flyback,
  then tap the fork with a dowel to get it to vibrate.   could I get an induced field
  on the windings and if so could I place a magnet to keep an oscillation from the fork
  by means of the eddy currents?  Ehh, i,m sure it,s been done before can,t find
  anything on the net.
You ever seen those party bulbs that have a moving filament?  it bounces back and
  fourth and there is (I think) a magnet in the center of it.  It,s been years since I,ve
  seen one.
These links might be useful:
http://maxwell.ucdavis.edu/~electro/radiation/ring.html
http://maxwell.ucdavis.edu/~electro/radiation/dipole.html
Edit: I think Tom was talking about something like this
giantkiller
The precept needed for this is 2 browsers up.
Browse to here on the 2nd one to have the picture present
http://www.overunity.com/index.php?action=dlattach;topic=1872.0;attach=4962
and
http://www.overunity.com/index.php?action=dlattach;topic=1872.0;attach=4964
Notice the reflection on the 30awg windings. It waivers. This is a sloppy wing edge. These layers have numerous quantities of these. Sometimes they point at another one on another layer just like the ECD-TPU but randomly.
The wing edges are created by the iron windings. Each layer is an iron core transformer.
But check this out.
555 Tesla coil
http://tacashi.tripod.com/elctrncs/555sstc/555sstc.htm
And on the GK4 the iron core is also in the electrical circuit. This creates a magnetic field to be perturbed much similar to John Hutchison's experiments. He uses Tesla coils and perturbs magnetic fields.
Now there also is a large stereo wire winding around all 3 layers in 4 segments. Each segment is an untuned Tesla coil with 3 primaries in parallel but not bifilar or 3 Telsa coils sharing a secondary.
Each segment on any given layer at any given time is firing in opposition to it neighbors. Between the layers as the field builds it circumnavigates in opposition with its neighbors field. The middle layer is in opposition between top and bottom.
In comparison with the ECD-TPU the GK4 produces totally random energy distribution. The ECD-TPU has its field energy directed precisely into a receiving antenna. And the ECD-TPU, being only one control layer and external field for perturbation should remain easily controlled.
The builders of the ECD-TPU should have an easier time of control. They will see results. The GK4 is a multiple segment, multi-layer ECD-TPU but produces fireworks instead of a directed energy stream. That is why I achieved such horrendous results. Did you ever see J. Hutchison stick his hands in the videos? I am lucky to be alive.
In my build I am going to use 30 gauge as the primary and mass equalized of 26 gauge as the secondary. My primaries will be long and single layer to get the maximum direct 90 degree coupling against the lamp wire. This does work because each intersection is a micropoint wing. I will wrap the 26 gauge as a single blanket over the primary. Could this be a fire trap? I hope so.
I am building the new model ECD-TPU. Yes Marco, we are very, very close.
--giantkiller. Without any debunking, there will be more ECD-TPUs working come this weekend. If come Monday and the GK4 is still the only one, then this has been a huge waste of time and I will leave to do my own work.
--giantkiller. Git 'er done. This version, the ECD-TPU, is extremely economical and has been proven in alot of its operational aspects. Does this explanation make things easier to see?
