Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
turbo
Quote from: bob.rennips on June 29, 2007, 01:08:45 AM
1.  Radio Frequency interference - Take a look at the TV near the unit
I'd have to disagree with the radio interference based on the TV unit.
The videos of the working TV I've seen have not exhibited radio interference IMO.
hi Bob,
as you look in one of the video's you can clearly see that when Steven disconnects a bulb from the coil, the video camera responds heavily to the coil winding up for a short period.
then the control unit "pulls it down" again so to say, it stabilizes the coil.
i do not have the exact timeline of this ,but when i find a spare minute i will post it.
Marco.
giantkiller
Grab this file:
http://www.overunity.com/index.php/topic,712.msg37542.html#msg37542
Just a look see of the SM17(17.zip)
Well we do know this: SM is right handed.
Notice where and how he holds is left hand while the right hand is doing something with the coil. He is not holding his tie back.
On with the show...
The 2 inner coils in the SM17 are wound alike but facing 180 degree out of phase. You can tell by the matching gaps. The black
base that they sit on have a positive and negative bayonet connectors but are not used(17-43). There are 2 fuse holders on the
back(17-54). Once again, one is empty. I contend that is for reduced power out. The remaining fuse is a spark gap. Why do you think I bought 2 stunguns? I am hot to trot on the FET driver for portabiity. I can't test around my network anymore.
I contend the control box is an empty audio ampilfier housing (17-50). Remember the paradyme shift (www.paradyme.com) in response to my dolphin wave post? He places the left and right channels on it. Just have the 2 fuses in
place.
There are bayonet connections at the same symmetrical place on the opposite(left) inner coil and 2 rc tanks in the background
(17-5, 17-49).
And there is a symmetry to the wing edge for a winding type on the right side of the ring(17-41). And then there is fine winding
on the left side of the ring(17-38). The larger ring windings match the symmetry of the smaller halves of the inner coils. The ring
is split in half or has 2 sides of operation? 2 inner coils, 2 mains going out, 2 fuses, 2 switches, 2 tanks circuits, 2 ring windings, 2 frequencies, 2 spark gaps, 2 large caps(white front and back of control box).
If he is using the whole ring in 2 segments/halves to do phase cancellation across the center where the inner coils are and then bouncing or transmitting that with the RE from the spark gaps then sh!t, there is your monster power right there.
Or it is lke I said many moons ago. 'The SM17 was always on and is the radiant tranmitter. Remember the 2 Frequency turn on switches? They don't do jack. The little tpus are receivers'. How do I know this? Marco did that show and tell right after
I posted that. He has never been wrong. How did the SM4 work outside? It works anywhere on the planet! And some of you argued about that. Telsa told us this. It is instantaneous. The SM4 and 6 put out dc not ac. The 120 volt devices were The Pledge. The
light bulb glowing was The Turn. We have seen The Prestige and part of answer. We just need to find the lever that works the trap door in the stage floor. You remove the fuse from the SM17 and the little TPUs won't work. What? Think about that from the Tesla viewpoint. This is a demo of the car that Tesla drove his nephew around in.
The open units are self contained. They contain transmitters, receivers, flybacks/stun gun single stage transformers. The
flybacks are the RE generators. This unit has sharp edges on a horizontal plane.
We use electricity to create a radiant field. That is when the energy is faster than the conductor and has a great need to dissapate. The sharp edges eject the radiant energy through space. The downgraded energy is now magnetic. The magnetic energy is a demodulation of radiant energy. This follows the Power transmission 'Inverse Squared Law'.
http://hyperphysics.phy-astr.gsu.edu/hbase/forces/isq.html
http://en.wikipedia.org/wiki/Compton_scattering
The open unit can also use the latch mags to create an RE drain. A transformer can be used to capture that. This could then be
input to the flyback or stun gun stage. And we then fire the coils again. It's all about the timing. Mosfets might make a difference.
But wait there's more! The GK4 tests were done with BJTs (Bipolar junction trannys). Hmmm.
Proof? I put the alum rings on a seemingly dead coil (GKMTC1) and it bit me. BJTs again.
Now in the ECD, the 6" edge shoots the RE into space. The closest conductor is the 4" loop and the RE drains to that point.
At that point the RE slows down at the copper and it relaligns along the angular vector of the Poynting vectors. The copper
then conducts it away.
So the stages are coils in parallel and series. A magnet wrapped onto the input of the flyback/stungun trigger, The secondary
as an integral winding of the coil inductively coupled back to the coils in parallel and series.
This is a test after my setup is done. When I fired the GK4 with the stungun I didn't have a way to collect it. The iron wire
would not have worked because it was connected to the frequencies. Therefore not a stable magnetic drain. But the Noemag
in the center vibrated to beat all. I should have wrapped wire around it. Now I see the potential way better.
Sm glued the 2 inner coils on top of the control box with the same silicon glue that he patched the rest of the unit with(17-37).
He used the edge to clean cut or wipe off the loose strings.
Is that a capacitor(paper wound), diode, or resistor in that bundle (17_32)? 2 matching tanks to the bigger tanks, the rings and
the big caps with an rc time constant in there.
I would be willing to bet the bundles are resistors. All big component pairs have a smaller sibling pair!
There are 2 connections to each of the fuse holders  (17-3). This has serious implications against the staus quo.
I claim the control box doesn't do a thing. It is empty and it has the oscillator components wrapped around it. That is why SM
showed the disconnected terminal connectors. Just like the empty fuse holder. He would simply state 'Test connections' to
anybody that asked(17-25).
I would even be so brave to say that he has extra wires(17_24) with extra connectors and loops.
Well 17-20 shows a slight back shot of the control box. Nothing to see.
17-19 shows the back shot and again nothing. Looks like the white cap is just tucked up along side.
17-18 shows the cap connected to the inner coil and the nylon connector. Where does the front cap connect to? It could
come under neath and in parallel with the back one.
Uh oh! The fuse wires cross. Maybe a mobius connection from the center(17-14)?
17-13 is a good shot to trace that out. You can even get a mobius arangement by putting one of the inner coils 180 in the
opposite direction.
Nothing on the back side of the control box(17-12, 17-11). Could be just holding a small battery pack. The access into the
control unit is underneath it.
An unequivocable shot of the fuses. Like searching for the Titanic. This should be enough to spur more interest. I need to
get to building. Again! Somebody look these over who doesn't want to or can't build.
This is Tesla's remote control boat demo. It has the RC circuit feeding the oscillators, 2 tank resonancy (the big caps and
rings) reception circuits and the spark gap for the telegraph key transmission of power all in one unit. Oh sh!t the SM 17 uses
the big ring as the radiant amplifier and the feedback to itself! I did this with the stun gun ezflow loops! The big units are self contained. The little units listen to the big units.
The pledge, the turn, and the prestige. Nothing is worth giving away the secret to your trick. For without that you have
nothing. Remember who the audience is.
I grew up on the rough streets of Philadelphia. I don't trust dog and pony  shows regardless of what the show is.
All of the demos are in the same abode. But the distance doesn't matter.
--giantkiller.
turbo
he energizes the coil by placing a large speaker magnet facing south on the side of the left little control coil inside.
then he puts the magnet faced north on the right side of the other control coil.
and then he takes little magnets and he "fine tunes" the outer ring segments.
you can see all of it when you focus on the video's.
Marco.
giantkiller
Painstakingly through the muck and mire.
--giantkiller.
turbo
hi GK  :)
that looks like a 4? channel drive.
verry nice.
Marco
