Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Bruce_TPU
Quote from: giantkiller on July 03, 2007, 02:50:48 PM
So in essence all 3 control coils are firing with 1 frequency of 1khz at 12v pulses.
GK - Is each of these three signals different sources?  If so, we have Identical signals/different sources, opposing one another.
I attach my new OWON scope to ground of the FET ckt and put the probe on the Drain of the 1st fet. The other 3 FETS are pulled out. I set the probe to 1000x probe setting, turn the voltage setting to 5v/div. I then turn on the FET circuit. The screen shows the 12v square wave of 1ms pulse width of 50% duty. On the leading edge I have spikes that are taller than the screen. I change the V/div to 5kv/div. I still cant' see the tops of the spikes. I turn the midline voltage down all the way. The pulses go below the screen but the spikes are still to high to see the tops. I dont get it.
???  Either - Wow!! or what?
I had to get ready for work. I turn the circuit off. I touch the heatsink and it is hot. I come back to the circuit 45 minutes later. Something is fried. I need to see about this later. If I blew a FET then I am in the club just out of the starting gate.
Sorry you fried something. Hopefully it will be a quick fix.
Something about the infrastructure is wrong and broken. This is a project of perseverence not production, yet!
--giantkiller. After all, it is 4th of July here.
See above.
Warm Regards,
Bruce  :)
Thaelin
   UH,,, GK,    wrong type of fireworks   :o
suggie
  Check that your fet is turning off after use and not hanging  in the on state. I have some fets here that from the get go were on. Only turn off when I brought the gate low. These are the ones that I thought were bad from the start. Just need a pull down resistor. Try about a 1k to start thats what I did.
giantkiller
Hi all,
My scope probe is not set right.
If you look at the schematic you see that the primaries are all tied together. So one 1 freq hits them all.
I will try 10k pull downs in case there is another problem somewhere else. Just to be sure.
I will try higher freqs > 10khz lower duty cycle.
I just turned it on to see. It's all good.
But now that my platform is in an executable state I will continue my diabolical plan to take over the world!
--giantkiller.
Moab
plan huh,,, GK you kill me,,LOL! :D
