Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
FET driver board status update:
I need to increase the noise filtering on the powelines of the clock board itself.
I have pin sockets for the potentiometers to hook into. I am not at ease with the lack of secured connection. I will remove them and solder the wires in.
I am tempted to put an external socket in for capacitor replacement on the 555s.
--giantkiller. Perfection must be attained in order to take over the world!
innovation_station
guess what guys
ha
i guess i got some of it back
how about this idea for how the tpu might just work!!
like ottos coil with a 4 " and a 6" coil
i dont know the exact freqs but but i think they have to total close to 7.8 but not too close so make 6" coil resonate at some where round 4 hz and then make the 4 " coil resonate at around 3 hz so i  was thinking to tune or make them run around that speed then pluse each coil with a diffrent freq ok so i still think it has 3 layers the collector coil is in the center and it is tuned close to 7.8 hz and a 4" and a 6" coil on the bottom and the same on the top then u pluse a 4 " and a 6" 1 from the top and 1 from the bottom when you get the kick back it goes into the 2 other coils to power them so i think u pluse 2 freqs at the same time 1 to each of the coils when the 2 freqs come togather they will equal close to the freq of the center collector and make it ringgg  once you have the collector ringging then i think that is the most part of the tpu but the high voltage kickback should power the other 2 coils and once you have got to the voltage that is safe for the coil you can then extract power from it  i think pancake coils must be used as a base coil then 1 control winding on top of it and if you use a steel wire on the coils as a final wrap the power will ark to the collector  in the center from the top to the bottom as you pluse it i think the tpu is quite similar to a homopolar generator the eddy current thing the opsing magnetic feilds the 90 deg cuppling from the mag feild to the copper  so similar  but we dont have to turn it cuz the electricty is turning
so i hope this helps i took some pictures of my last coil it is for my homopolar generator but my tpu coil fits right inside of and humm i have been having some fun with this combo
ist
@gk
so in your last post it seams you say alum wire plate or collection contraption to to convert  our re engery to usable power is that correct? so alum insted of steel have not tryed it yet but i must
ok now it is really comming back to me and i think it is because im working on the homopolar generator right now but here we go agin
so gk aluminum hummmm      well what i know so far about alum is this when i mad a proof of concept tests for the hpg i used alum disc it made power around 3 volts dc and it  GOT HOT  WHY?  well why does the tpu get hot ?  and can not be cooled by a fan? when i took power it got hot same with the tpu  so tesla built a special generator with iron copper and alum hooked up in a novel way right hummmm
ok with alum it makes its own power from a magnet like a superconductor material but it makes opsoeing it is like how a dynmo works and similar to induction heat furnice also in a microwave oven how the transmitter is made of copper 2 ring magnets and alum kind of like a cap and hv power is fired through the center of the ring magnets its is similar to the tpu but we use electro mags
ok so a cap is made of alum and that is how we are changeing our re power to dc or ac power also if we bounce the electro mag feild around in a circle seperated by however many sections as we want to use unless the layers are inter twined
ill leave it there 4 now but i have more thoughts yet about it
giantkiller
Perturbing the magnetic field sets up a Kozyrev detector.
? A body placed for a certain time near a process [that generates torsion waves] and then brought to a torsion balance [would] produce the same effect on [the torsion balance] as [the original torsion-generating] process [produced by] itself. [The] memorizing [of] the action of processes is a feature of [all] different substances, except aluminum.
--giantkiller.
EMdevices
wow, the brain power displayed here is stagering.  Who wants a Nobel prize?   Just raise your hand.  :)
My turn, here's how I think the TPU works:
We basicaly take energy from the natural magnetic field of the earth, which has an inherent frequency, we basicaly tune into that, and take the energy which is readily available from the earths magnetic field, and produce electricity from it.
EM
z_p_e
Quote from: EMdevices on July 06, 2007, 10:19:45 PM
EM
LOL, that cracks me up! Good one EM.
Darren
