Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
giantkiller
@Mannix,
The circuit is a stripped down stun gun oscillator. ;)
--giantkiller.
giantkiller
Every step of Tesla's power production methods produced more and more RE each time.
Now in the stun gun we have a spark gap, inside and on the circuit board, and diodes sitting close by. The diodes are always sitting close by. Hmmm... You only ever see the external spark gap.
One does not need to drive the circuit with excessive high speed to produce RE. But you do need a spark gap with diodes close by. What? How about FETs? And with aluminum heat sinks the mag field is reflected back onto the coil.
The RE effects the coil at very high speed. That is where we get our speed. Stun guns only run at 6.66k but we get high speed RE.
Inductive winding is only a later capture part and not a generative part. The open TPU uses aluminum reels. The field from the bifilar winding is reflected immediately back to the secondary. Mag amp.
Theory? Wardenclyfe is a massive stun gun. The TPU's many windings perpendicular to the collector perform as a massive array of RE couplings.
You can play with theory all day or just strip a stun gun and be amazed. Better yet, cross couple 2 stung guns, fire 1 and watch them go around. Or cross couple 4 of them. That's right. Remember when SM hold the 2 leads and produces spark? Well what the hell do you think is doing that? Right. It's a stun gun.
Thank you for the aluminum, Dansway. And the fets in the middle, Roberto.
See what happens when you build? Remember all the hub bub over the 5k frequency? Hmmm.... Well here we are again.
So the spark gap generates RE that flies through space to a collective element. The rotating magnetic field swings past inductors to be picked up. The Bedini little girl motor executes magnetic shearing which also acts like a dynamic diode. So the one wire circuits are RE receivers.
So alot of these things appear in many forms all over the place.
--giantkiller. Another great step into the future. RFC. :o
Mannix
GK,
The transformer would need to be round,other wise our field could not speed up..it just goes backward and fowards..like every single circuit that we design...... we have not learned to use our round transformers properly yet.This, I think may be  the  HUGE difference between round things and square things..Could it be that simple?
perhaps man has only just started using the potential of wheels.....errr I mean  round things...
Lindsay
Motorcoach1
@Lindsy I posted this to Gk months ago ., just take a scotch tape roll the plastic  pice- get the magnetic pice fron a shower door and cut it to fit in the recesded part of the round part fo the soctch tape roll , that would be south on the out side and north on the inside , put 8 winds of 16 guage on the primeter and wind the outside parelle in each half equal 22 turns , put the current to the radious and the pisitive to the oppisots ot the half pallrlell turns and add the freq bi lad in (-) see what you get mmmm and mesure the current .
Mannix
