Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 42 Guests are viewing this topic.
Mannix
Motorcoach,
have you a picture of your setup or is it a thought version
GK,
a bias resistor between 1 and 20 k from power to base....not sure about those damping resistors.....
On a torroid please...perhaps a magnet strip who knows?..perhaps air?.have a good play.
get a few magnets and you can make a sort of magnetic fence.
This could be just a toy it does not  matter it looks like the video..it plays like the video...no power ....yet but you cant have everything at kindergarden
lindsay
Motorcoach1
Manix this is it if it will post
joe dirt
In looking at this animation:
http://web.mit.edu/8.02t/www/802TEAL3D/visualizations/magnetostatics/coilsaligned/coils_aligned_640.mpg
I can see the Helmholtz has a uniform field, but what if we placed a permanent magnet
  to one side of it, would the expansion and contraction of the field act like a "whip"
  to simulate a pulse on the middle collector (refer to the pic)?  could this create
  electron flow on a conductor?
giantkiller
I got the first fet driver mini board repaired. The fet driver is the max621. Max speed is 58khz.
The fet is 110 degree faren. no fan.
The ECD output pulses are 264v, the inputs are 12v.
The current draw is 10ma.
I charged a capacitor thru a 1n5819 schotky connected from the zero line to diode to
the positive side of 400uf cap to the phase line.
I disconnected the cap and put an led across the cap and it fired up briefly. I did leave a diode in place and it stayed lit.
Nice little test. But I had headaches for 3 days since I have been using the new fet driver on my ECD. I woke up last night at 3am with a real banger in the skull. I should know better by now but the shielding doesn't work as stated on another thread. Motorcoach stated he is 30 feet away. I will now work more distance into my lab work.
If while pearing at instrustments, nothing is seen. That doesn't mean nothing is happening. Madame Curie had this same problem. We are trying to kill giants with flyswatters.
Next I am building 3 more fet mini boards based on the tc4427. Looks like I can get this one to run up to 800khz. :o
I will test incrementally with each new board and frequency.
@Dirt,
Another nice graphic. I will familarize myself with Openfx while on the plane for vacation.
--giantkiller. Thats all for now.
giantkiller
So it looks like the TEM(our current power grid configuration) is a closed loop or circular path and the LMD(natural conductivity) is an open loop or linear path.
My next TPU configuration will be be jumpered to match the LMD as proven by JLN and Dollard. It matches the multi stage stungun.
Conventional laws of physics are crap. It is time to stay out of the box.
Tesla stated and Dollard restated that Tesla could achieve a tunnel between the transmitter and receiver. Could be warp travel, time travel or  distance transporter. Dollard just threw it together and got results. Forget the normal crap and build the new crap.
The ECD control coils represent the Tesla magnetic transmitter. Primary and secondary volume matched. The ECD is an MT with the Transmitter and receiver inherent in the same unit. So the  RE has a very short distance to travel. Like it matters!
http://video.google.com/videoplay?docid=-6461713170757457294&q=eric+dollard
@Ironhead,
Got it, Sir.
-giantkiller.
