Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
0 Members and 61 Guests are viewing this topic.
giantkiller
@acerzw,
Sure. I will post everything. Sharing is caring.
The only complicated part would the asm for the 1, 1.5, 2 modulus freqs. I have to dig in the manual to see their mult and div statements. If that is there then piece of cake. Actually that is a stupid statement. I just figure out the bit count to speed and dump that into the counter registers. I'm done. 8)
I did realize that there are quite a few posts on the freqs and jdo300 is heading that way with a uchip & digital signal chip solution. We talked about the Parallax quite a bit. It is agreed that the digital control would be the best. Analog jumps and could jump into a banger. That was proved in my last scope movie on youtube.  :o  I connect all this in a bit.
Now for some history:
Tesla stated that the spark killed men, metallic objects became charged. Those 2 statements imply power and field size.
Now my part. Whoever has not been to my website then they will not know I have stainless steel in my feet from an accident. I also carry the staphylococci  from a hospital accident. So I kept my coil generated field size below the 2 ft radius to keep the field from the metal in my feet. I cannot afford to have the metal discharge at all and cause any blemish on the surfaces. The staph would rush to the site and cause infection. Already been there, am not going back again.
Now you all understand my harping on safety.
We will now return to our regularly scheduled program.
--giantkiller.
acerzw
GK,
     When I try to view your website I just get a blank page? is it working?
acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
bolt
Here is a very nice audio amp i found with a quick google. Very simple class A mosfet amp which is DC coupled and will have extremely wide bandwidth should easily run DC to a 1 meg i recon. The only drawback is the split rails supply but hey if your going to do this then give it the best shot. If it works then scaling back on quality can come later and you can then use this a very nice home hi fi amp so it wont go to waste no matter what happens. I heard this class A stuff before it just has to be heard the difference really is amazing! Even at 3 Hz your speaker cone will just move in and out like a piston LOL and this is exactly what SM is describing to make the TPU work.
Half way down this page http://www.geocities.com/leobodnar/audio_amplifiers.html
i didn't know you was bionic so better use a handheld kill switch instead.
Mannix
That is a nice starting point for a mosfet audio amp...if only you had a running coil to use it on you
might be able to learn to protect it somehow ..it only took Steven 10 years to do so.
I wonder how it will respond to 5khz spikes and wide band RF hash finding its way back to the output fets?
read his stuff again, this is futile for me
I 'm done here, for a time much longer than those fets will last.
bolt
easy.......there wont be any RF nor pulses. This is a musical instrument and such no RF should be generated. Do your mains transformer at home create RF and hash? Mine dont.
