Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
BEP
Suggestion (my new coils are not complete yet):
If we are inputting the effect to create the cause (harmonics to create sine) then input the signal we expect and see what comes out. Will it be the unknown frequencies?
You can split light with a prism. You can create laser light by combining frequencies.
bolt
Be careful about the definition of a harmonic. Wiki say this about what is a harmonic
"the harmonic of a wave is a component frequency of the signal that is an integer multiple of the fundamental frequency. For example, if the frequency is f, the harmonics have frequency 2f, 3f, 4f, etc. The harmonics have the property that they are all periodic at the signal frequency, and due to the properties of Fourier series, the sum of the signal and its harmonics is also periodic at that frequency."
However, harmonics in electronic circuits are often created unintentionally when we create distortion. Theses harmonics are  nasties and degrade from the purity and stability of our precursor catalyst.  SM comments on this in his notes.
BEP
There is quite a bit about harmonics that isn't in Wiki or the books. We are dealing with more than the electrical component. The electrical side is pretty clear and proven. The magnetic side is also well written but like so much in classic physics it is assumed one case fits all.
The formulae change when moving from far field to near field. On proceeding or receeding the strength of attraction/repulsion changes radically - so does the speed of the object acted upon. Space and time are opposite sides of the same coin. If you distort space you also distort time. Like mass magnetics have the same effect or so I have proven to myself.
You should find that harmonics are not always integer multiples - from your view as the observer. While from the fundamental's view they are. This is one reason why velocity factor must be considered when designing a transmission line. Current speed - and therefore the magnetic field speed isn't the same for all conductors - from our view.
giantkiller
Yes. I realized this over that last few days. The DACs operate strictly with integer values doubled. By using these the other fidelic features of the harmonics will be missed like .2, .3, .5, .7, .9 portion of a wave. Analog control gives a wider control into the color of the sound. Very interesting google.
Sound will be the medicine of the future. - Edgar Cayce
http://www.biowaves.com/
--giantkiller.
acerzw
GK,
where are those two pictures you posted from?
I like the tesla one, which tesla patent is it from?
Acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
