Lords of the Ring
Started by giantkiller, January 06, 2007, 11:53:14 PM
Moab
Did anyone try to view the video? I tried to download it and it didn't work . said it wasn't a .mov file. Let me know if you guys/gals are able to open the files i post. otherwise it is a wast of band width. Many thanks. MOAB
Thaelin
   Well the RF Flame worked ok but the other had some kind of error in it and would not play at all. That was with the latest QT player. Definitely RF in nature for sure.
   Noticed you are rotating the coil segments as you stack, is that correct?
Off to the surplus shop, just called to tell me that he has some >5000ft rolls of different sizes and types of wire. The word cheap is the clencher.
suggie
MeggerMan
Hi Moab,
Yes, the second video RF_FLAME_Colector2.MOV works fine, but the movie NEO__MAG_FIELD.MOV fails to start.
I may try it later on my Linux box to see if that can run it.
How did you do the white lettering artwork on your PCB, did you screen print it on?
Unusual spark sequence, I am guessing it needs to arc to get the current to flow to create the high voltage.
I have seen this sequence before when a substation insulation breaks down and the resulting spark is tens of feet long.
I was trying to firgure out your sketch, but could not see a logical pattern in the field sequence.
Rob
Moab
@ Meggerman,How did you do the white lettering artwork on your PCB,?
My good friend owns a company that develops R/C for any application you could think of He has a plotter that prints and punches PC boards\.
@meggerman, I was trying to firgure out your sketch, but could not see a logical pattern in the field sequence.
The top(Work of art) LOL.  Is in linear format. as if you were to slice the coils and unroll them, the bottom is from left to right as you would stack the coils the colors are the different segments. Just a quick and dirty sketch to give an idea of how this monstrosity is configured.
@Sugra Noticed you are rotating the coil segments as you stack, is that correct?
Yes they are rotating CCW..
                           MOAB
                                      Moab
mflynn44
Hello all,
from http://www.stralingbewustzijn.nl/schone-energie/index.htm
Oscillator with two acceleration coils
Also as not inductive coil or Bistroem oscillator marks.
The two coil oscillators must be equal strong identically and.
They are switched together phases rotated as bridge.
The magnet cores or tube amplifier work as ZPE- magnetic flow accelerator with pulsating direct current, not with alternating current. Therefore for an independently reciprocating current generator at least two separate magnetic flow accelerators are needed, which pulse as bridge changing.
If a magnetic river flows parallel to an electrical conductor, its speed is multiplied.
If a magnetic river flows parallel to an electrical conductor, its electrons are loaded (doped), and generated from available particles such as Helion 1 and 2 a centrifugally accelerated magnetic (Protronen) river. Thus the magnetic river is concentrated and accelerated.
A magnetic Protronen current results in the leader due to the surplus. This current evades because of lack of space of the center from to both ends, moves in accordance with (rights handregel) as spiral around the leader, and radiates.
The two coils with a Kondenstor can swing with their periodic resonance.
The two coils can be wound also on a core next to each other.
See generatorgenerator generator:
The pole direction of the magnetic field is unimportant, because the field flows only slowly.
The field from the next smaller particles (deutron) circulates inside than giving strength.
in German:
Oszillator mit zwei Beschleunigungsspulen
Auch als nicht induktive Spule oder Bistr?m Oszillator bezeichnet.
Die zwei Spulen-Oszillatoren m?ssen identisch und gleich stark sein.
Sie werden Phasen verdreht als Br?cke aneinander geschaltet.
Die Magnetkerne oder R?hrenverst?rker arbeiten als ZPE- Magnetflussbeschleuniger mit pulsierendem Gleichstrom, nicht mit Wechselstrom. Deshalb werden f?r einen selbstst?ndig oszillierenden Stromgenerator mindestens zwei getrennte Magnetflussbeschleuniger ben?tigt, die als Br?cke wechselnd pulsen.
Wenn ein magnetischer Fluss parallel zu einem elektrischen Leiter flie?t, wird dessen Geschwindigkeit vervielfacht.
Wenn ein magnetischer Fluss parallel zu einem elektrischen Leiter flie?t, werden seine Elektronen geladen (gedopt), und generiert aus vorhanden Teilchen wie Helion 1 und 2 einen zentrifugal beschleunigten magnetischen (Protronen) Fluss. Dadurch wird der magnetische Fluss konzentriert und beschleunigt.
Es ergibt sich im Leiter auf Grund des ?berschusses eine magnetische Protronen-Str?mung. Diese Str?mung weicht wegen Platzmangel von der Mitte aus zu beiden Enden aus, bewegt sich gem?? der (Rechte Handregel) als Spirale um den Leiter, und strahlt ab.
Die beiden Spulen mit einem Kondenstor k?nnen mit ihrer Eigenresonanz schwingen.
Die beiden Spulen k?nnen auch auf einen Kern nebeneinander gewickelt sein.
Siehe Zyklonengenerator:
Die Polrichtung des Magnetfeldes ist unwichtig, weil das Feld nur langsam flie?t.
Das Feld aus den n?chst kleineren Teilchen (deutron) zirkuliert innen als gebende Kraft.
Can somebody provide a better translation into English?
The website referenced above has a lot of information regarding collecting radiant energy. Actually, he provides a good description of how the TPU should work; it's just a matter of changing a few connections on our present TPUs.
Michael Flynn
